Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Why can't I copy larger files than 4 maybe 5GB to my passport WD? Is there a quick way how I can change this?
  • 560 Answers
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive:
-insert external drive
- open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System".
-click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
Posted on Aug 25, 2010
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
When I plug in my WD My Passport drive I am asked to format it. I can read any files
Try running a scan disk and/or defrag it and see if it helps. If not, maybe you can trying copying all the files to another drive and then format your passport drive. After that, copy everything back to the drive and work normally with it.
Hope that helps!
Feb 05, 2011 | Western Digital My Passport Essential SE...
I'm not able to write files to my WD passport drive. It works fine in XP, but I have a Mac only..really not sure wat to do here..sos!
If the WD has been formatted in NTFS then the MAC cannot read or copy to this hard disk.
To make it compatible for the PC and MAC, format the WD Passport drive on your XP computer in FAT32 format. Then you can copy and exchange files between the PC and MAC.
Dec 26, 2010 | Computers & Internet
How do I restore my files on my passport to my internal hard drive
Why not make it KISS (Keep it simple and stupid). Go to your my Passport folders or files that you want to copy, Click on it and Copy (ctrl c) or Cut it (ctrl x), now go to your internal drive (C:\ or D:\,etc) and do Paste (ctrl V. You can also copy or cut multiple files or folders.
Sep 03, 2009 | Western Digital WD Passport 250GB Portable...
WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Apr 29, 2009 | Western Digital Passport 320GB External...
Can't copy files to drive. Says disk is full and it is not.
what filing systems do the passport drives use and how large are each of the files ?
If they are fat 32 and the files are each larger then 4gb then that is why it will not work as fat32 does not support or allow more then 4gb per file due to the filing system so you would need to format it as NTFS if you want to store files larger then 4 gigs
Apr 14, 2009 | Computers & Internet
Cannot copy large files onto my WD passport
Your drive is probably in FAT32 format.  FAT32 has a 4GB file limit that is why your 5GB movie isn't saving.  You will have to format the drive in Mac OS file format (HFS) using Disk Utility.
Unfortunately once its in Mac format the drive will not be recognized by windows PCs.  What I do is have a program called macdrive installed on my windows computers so that they can access mac format hard drives.
i hope this helps!
Nov 13, 2008 | Western Digital Passport WDXML800UE...
WD3200ME-01 Passport size diskspace problem
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Jul 03, 2008 | Western Digital 320GB MyBook External USB...
WESTERN DIGITAL 320GB PASSPORT USB PORTABLE
Doh
After posting the above, I found the answer on another forum about 10 minutes later. The WD drive is formated in FAT 32. My XP PC HDDs are formated in NTFS. FAT 32 has a 4Gb file size limit.
Answer. Format the WD drive in NTFS. It takes about 10 sec to do a quick format, but of course you lose all the content. Then You can copy anything you like to it. I have just copied a 33Gb video to the disc.
May 09, 2008 | Electronics - Others
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
163 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
