Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My flash drive was working fine then one day it said everything has either moved or changed and that the shortcut is no longer available. ..what should i do to recover it? it has pics that i dont want anyone to see......:(
  • mmalloy65 Aug 25, 2010
    It says the file that it moved to no longer exists....Fiyem.exe in properties, but when each folder is clicked on in explore it gives me the option to "test, install, configure, or scan with avg"....not the normal "open, etc.) and each folder said it had been moved to tuexuu.scr. About an hour later I couldnt even open it from "my computer" . It just came up with a message that said said Fiyem.rar. I looked these up and the only explanations I get are in different languages. My friend tried to open it from his computer and it gave him a big warning that it could be a bad virus and not to open it. I am just sick about this. It has more than a whole lifetime of my family pictures, but legal stuff for my child custody case against my ex. Its the only copy I have. I know ...I should have....would have....but that doesnt help me now. I will make a backup next time. Please anyone...someone....I am desperate and broke so I cant pay for some pricey place to fix it. This sounds so pathetic, and I am so embarrased.
    Problem Solver:
  • 4 Answers
Try going to your start,then click search and type in file name your looking for...maybe someone moved it or deleted it..You can also go to start, computer, (with flash drive plugged in) then right click on your flash drive and select search and type in the file name...
Posted on Aug 25, 2010
I had plugged my computer in the other day, turned it on and it worked fine. I put in a flash drive to copy somethings to it. Put the flash drive in, finished with what i was doing powered down and...
I guess you tried restarting the computer a couple times. You didn't accidently send the "C" drive to the flash drive? Have you tried putting the flash drive back in (if it hasn't been changed) and tried booting?
Dec 30, 2013 | Sony VAIO Notebook
Incorrect Date
open shortcut on pc..it will show correct date, time, etc tho unit does not as it hasn't changed days..on the shortcut, click on Update settings then Send to receiver..then punch in button on back of Station..says "pc search"..transmitter on unit will start steady flashing..unit will go black..gradually everything comes back..don't touch until all back..everything will now match the stuff on the shortcut and the day and date will have changed to the correct one..I do this process every day.
Jun 01, 2012 | Sharper Image 5 Day Internet Weather...
The item 'quwof.scr' that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly.What do i do ?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 03, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
The item that this short cut refers to has been changed or moved, so the shortcut will no longer work properly. (error i am gettin)
The actual program/document the shortcut points to is probably deleted or moved. to make sure, right-click the shortcut > "Shortcut" tab > then check the "Target" path. modify it as appropriate or just reinstall the actual software.
I hope this helps
Jun 12, 2011 | Compaq Computers & Internet
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When i click on the Google Chrome desktop icon Chrome WONT start. Instead i get this message: ''The item 'chrome.exe' that this shortcut refers to has been changed or moved, so this shortcut will no longer...
You might want to try restoring your system (using "System Restore") to a day when you remember the application running correctly. If you cannot do this than yes you will have to uninstall/ reinstall the application. Thanks, Dana
Feb 14, 2010 | Google Chrome
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
I installed luxor 2. it wont let me play.it says,shortcut refers to has been changed or moved so this shortcut willno longer work do you want to delete this shortcut?
Hi-
Delete the shortcut and look for your luxor2 folder under program files, then right click on the luxor icon and choose create shortcut and drag it on your desktop.
Update me or keep me posted on result
Aug 02, 2008 | Computers & Internet
Games aren't working properly.
check the setting for the game may be u have disabled it unknowingly.
May 14, 2008 | HP Pavilion dv6000z Notebook
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
37 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
