Question about Microsoft Xbox 360 Console
X box problem
My ex box wont come on it keeps not booting up and the control sensors are coming ont red instead of green
  • ishchicano May 07, 2008
    wen i turn on my 360 the green power light turns red and flashes. nothing comes on the tv screen.
  • Edward Stewart
    Edward Stewart May 11, 2010
    How many red lights are flashing all 4 or only 3 of them? Less?
You likely have the "Three Red Rings of Death", which denotes a hardware failure. You can check on Xbox.com, they have some troubleshooting options that might help, but you'll probably have to send it in.
On Xbox.com you'll find a telephone number, you call in to Microsoft and file a claim. If your console is still under warranty (they extended it, so unless you've been messing around with it and broke the seal it shouldn't be a problem) then they will send you a box for it. You send the console in and they will either fix it or give you a new one, then send it back to you. This is all free of charge.
Posted on May 08, 2008
Tip
What to do when you only have Green on a CRT Projection TV.
If you have a picture, but only in green on a 3 crt projection TV, I would try turning up the drive for the red and blue guns. They have probably changed over time and red and blue have lost drive and need a boost. Green makes up 70 percent of the picture compared to red and blue so the drive would not have to drop much to lose red and green but still have green. Keep in mind that this does mean that the CRTs are dying and may not have too much time left.
To turn up the drives first remove the back cover on the bottom half of the machine. Be very careful as you will have to work on this unit live. Do not touch anything other than what I tell you and keep one hand in your pocket whenever possible.
First look at the space above the main circuit board. Somewhere across the beam supporting the CRTs you will see a square box with 6 controls (shafts). You can locate the box if you follow the wires from the flyback to the box. The flyback is located on the power board and produces the high voltage. It will have 4 large red rubber wires coming out of it. Three go to the focus divider block (the box in question) then they go on to the crts (red, green, blue).
Once you locate the focus divider look at it closely. The focus controls are on top and the drives are on the bottom. They should be marked red, green and blue. You want to turn up the red and blue. Tune a picture with as much black as possible. While watching it turn up the red until you see a red tint or streak then turn down until it just disappears. Do the same with the blue. You may want to touch up the green also for good color balance.
If the set is working OK and the CRTs have enough drive left, your picture should look normal.
Thanks for using FixYa.
hardrocko
on Sep 22, 2010 | Toshiba 50H81 50" Rear Projection...
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
My playstation turns on and everything, but once i plug it in to any kind of television there is no picture or sound
Heres one solution that I found. If your ps3 turns on but does not boot up just stays a black screen most likely the hard drive got corrupted. So unfortunately you will lose all your saves. But to save the system when you power on the ps3 hold the button down its should beep once keep holding it and it should turn red in standby mode. Keep holding the power button down though. It should turn green again keep holding it should beep then double beep this time instead of going into standby. Let go now and some options will come onto the screen. You will need to plug in your ps3 controller and 6 options should come up. Reformat PS3 worked for me but I lost all my saves. Good luck!
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
Dashlights
Fuse 23 in the underhood fuse box, it is a red/green wire going to the combo switch, leaving the combo switch it changes to a red/black wire. All the illumination controlled by the combo sw. is a red/blk wire. Let me know if that helps, Honda Al
Mar 19, 2009 | 1990 Honda Accord
Changes batteries and button blinks green light and wont' connect
clikc ont he button on ur xbox that looks like a bunch of arrows then turn on ur controller....this should solve it, if not e-mail me at silenthunder101@yahoo.com
Jan 11, 2009 | Microsoft Xbox 360 Controller
Power will ont come on
check pico fuses f9a04 and f9a05. They will prob be open. if so, repl conv ic's qty 2 stk392-570 . you will need pico fuses 5A heat compound, solder and iron. also check caps in dm module. if swollen, then repl. there's 4. 4700uf 50v i believe. Also check to see if there looks like something spilled on the circuit boards. if so, your picture tubes red/green or blue may be leaking coolant oily substance. If this is the case, try removing the pcb and cleaning with 97% alc. They make good cleaning sprays too. The boards may be shot. good luck to ya.
Rob/ex mits service tech
Dec 30, 2008 | Mitsubishi WS-55857 55" Rear Projection...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
CASIO EXP600 Flash problem
Hi, I sent my camera to the dealer...thanks anyway, Sevendata
Apr 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
The red light on my amp keeps coming on and it wont work
You need to check your woofers. Most likely one or both may be a) blown or at a dead short or b) the ohm rating on them may be too low. What model woofers and amp do you have??
Nov 17, 2007 | MTX Thunder TA7801 Car Audio Amplifier
Microsoft Xbox 360 Console Logo
55 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
