Question about Garden
Mountfield SP535 ( Honda GCV 135 ) Petrol Rotary Lawn Mower instruction manual
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
huffman49
  • 235 Answers
SOURCE: cant get my mountfield lawn mower started, it is
make sure there is a spark plug in. that would be 1 reason why there is no resistance when you pull the cord. if there is a spark plug in then check to see if there is a clunking sound when you pull the cord if this is the case then the engine has a broken conecting rod..good luck
Posted on Apr 07, 2010
SOURCE: mountfield mower manual
need wiring daigram for mountfeild 14104 ride on mower
Posted on Apr 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a mountfield sp470
Hi. The SP470 has a 4 HP Briggs and Stratton engine.
The part number should be 687171 and you can look here:
http://www.worldofmowers.ltd.uk/Products/ProductList.aspx?search=Head+gasket+&type=3&searchBtton.x=20&searchBtton.y=10
Take a good look at the valve end of the head gasket. From the pictures on the page you should be able to see which one of the 4 head gaskets on the page is yours.
If you have yellow pages you can look up lawn mower repair. Or small engine repair shops. All of them should have this commonly used headgasket in stock. Just find one close to you or.. use the link above.
Here is yet another link for the head gaskets but you have to scroll way way down the page or page search for 698717 or 272171.
http://www.briggsbits.co.uk/acatalog/Horizontal_crankshaft_2-7_HP_Sidevalve_Engines.html
Thanks for choosing FixYa.
Kelly
Posted on Sep 12, 2010
SOURCE: I have a Mountfield bvs153 petrol mower. The
It fails after it has 10 minutes to warm up right?
I think you should run it till it fails and then test it for spark.
My guess is that your coil is going bad and heat just triggers the failure. After a while even cooling down wont help.
The good news. If you need to replace the coil its a pretty simple job that can be done with a few hand tools and a new coil. It shouldnt be too expensive either. 25-35 dollars for a new one if your shop around online or go to Ebay.
The only thing special you need to do once you have removed the recoil cover and removed the old coil is to take a piece of thin cardboard *(I actually recommend the box the coils usually come in. But a playing or business card will do) Put this paper between the coil and the flywheel to set the coil gap. Tighten on the screws and then pull out the paper. Put the recoil cover back on and you are done!
Good luck and be careful.
Posted on Oct 12, 2010
How do I replace top crank seal honda GCV 160 engine
its not going to matter if the seal is leaking damage alreay done to it run it till it stops or lockes up
Aug 18, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Need a Honda GCV160 mower owner op-manual
You will need to know your serial number. They are free to download, but if you want to order a paper copy, you have to pay for it. Hope this helps and please don't forget to rate!
http://engines.honda.com/parts-and-support/owners-manuals/GCV160
Jun 24, 2012 | Garden
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
How do I put the belt back on my Honda gcv 160 self propelled lawn mower?
Hi bairboys,
Here is a link for your owner's manual: http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532430880.pdf
The instruction and belt diagram are on page 13.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Husqvarna 7021RH 21Inch 160cc Honda GCV160...
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
Hello I have a Mountfield MPR10071 46" power mower with a Honda GCV 135 4.5 engine just bought it second hand and its fine other than if you let go of the cutting lever it stalls! is it supost to do this ?...
I suspect you mean the OPC (operator presence control) lever? This is a safety feature - if you let go, the blades stop. Since your mower does not have a blade clutch, this means the engine stops.
All walk-behinds HAVE to have this feature if manufactured after (I think) 2002 in the UK - similar rules apply elsewhere.
There's no easy way to disable it - if you tie up the handle so you can empty the grass catcher with the engine running, you will find that you have no way of stopping the engine.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
Garden Logo
399 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
