Question about Canon imageRUNNER 8500 Copier
JAMMING IN DUPLEX ON REVERSE ROLLER
I've replaced the reverse roller. It stills jams with lead damage. When I replaces the entire dupled transport with another machine, it works fine.
8500 ir, code in jam history shows 0515, when using duplex in A-4.
Posted on May 16, 2008
  • 3 Answers
Just replace the duplex moter.
Posted on May 05, 2008
How can I stop paper jams when using duplex printing?
1. Replace "Roller top out put bin" (RL1-0527-000CN)
2. Clean duplexer unit & chk the rollers in size change assembly(RM1-1318-000CN)
Apr 29, 2014 | HP LaserJet 1320tn Printer
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
It has a code 1334
C1334 Duplex take-up print
command error
• A Duplex take-up print command is not received for
the paper to be taken up from the Duplex after the
paper has moved past the horizontal transport, but
before it reaches the Transport Roller.
• The number of Duplex take-up print commands falls
up from the Duplex, or the leading edge of a sheet
of paper, for which a Duplex take-up print command
is yet to be received, activates the Transport Roller
Sensor.
Apr 09, 2013 | Minolta Office Equipment & Supplies
Appear duplex jam at display samsung ML-2150
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
Jan 06, 2011 | Samsung ML-2150 Laser Printer
My hp2210 All in One will not print and makes a noise like a bearing knock on a car
Feed roller jamming? Or a gear in the transport system damaged, or a roller clip loose or sticking rollers. Only way is to investigate and see if the rollers move freely by hand
Jan 04, 2011 | HP 5510 4-in-one Printer
IR5570 jamming from paper deck #2 but having a 0201 jam code what possible solutions ....changed the feed sep and pu tires and also replaced paper deck #2 registration rollers going into the duplex...
Check the duplex motor that feeds the reg roller shaft - in the front of the duplex unit. I found one that was loose, when I opened the front duplex cover and moved the motor, the screw fell out! The motor gear and drive gear were not touching. Good luck
Jan 27, 2010 | Canon Office Equipment & Supplies
I have a Savin 9400 copy machine. It will not print 2 sided copies. Everytime I try to print a 2 sided copy, it jams after it prints the first side and before it prints the second side.
Hello sir; You need to clean the reverse roller with alcohal, if you don't know which one is reverse roller then you can clean up all the roller in duplex unit.
Aug 28, 2009 | Savin Office Equipment & Supplies
Duplex does not work
you must change fixing roller and the web (it cleans the fixing roller ) .
Dec 29, 2008 | Canon NP 6050 Copier
Jamming, roller lines and loud fan
You'll want to purchase the service manual for this printer if you do not already have one. Obviously the fan is the most annoying problem. But the jamming, the roller marks, and other issues would indicate that the entire printer is probably needing to be cleaned out and that the rollers may even need to be reconditioned or replaced.
Jul 23, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Canon imageRUNNER 8500 Copier Logo
257 people viewed this question
old marine
old marine
