Question about Lexmark X6575 All-In-One InkJet Printer
Says paper jam but there isn't one. Can't get it to work
  • 105 Answers
Paper will not feed
Hi, maybe there is still a little bit of jammed inside that you can\'t see. Try to see if there is and clean it. If you\'re sure there is no paper jam whatsoever, then there is a conflict with your feeding sensors or your cartridge isn\'t properly installed.
kind regards
Apr 17, 2013 | Lexmark X4650 InkJet Printer
Printer is in alarm mode stating a paper jam when there isn't one?????
Even though u cant see a jam there there is exactly a jam inside
U believe it or not thats why paper jam
Look for the paper detection sensor below the carriage
use ur common sense
I cant say exactly it is detect sensor it may be some other sensor related to gear wheel set
but most of the cases paper jam occurs due to malfunction of paper detect sensor
If u find it use a thin tool to see it is working properly
otherwise give it to someone know how to repair & pay a reasonable price
thx
Sep 17, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
CannonMP495- paper jam when there isn't
Because there might be small dust/paper part would be stucked at the roller sensor just make sure and make it clean you can find some dust or small paper piece stucked with your roller so its showing paper jam error when theres no paper inside.
Aug 12, 2011 | Canon PIXMA MP495 InkJet Printer
Printer indicates Paper Jam 2. I followed all the steps. However, there isn't any paper jam. How do I clear this error? It will not clear.
There is an issue with fuser exit sensor on this printer. They will report false paper jams. A small part needs to be replaced to solve the issue.
Jun 26, 2011 | Samsung CLX-3170FN All-In-One Laser...
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
Hi my printer is not printing, it stoped to work yesterday when I change the paper
Are you getting any flashing lights that could perhaps indicate a paper jam or maybe the paper isn't loaded correctly?
May 03, 2011 | Zebra TLP 2844-Z Thermal Label Printer
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Everytime I hit copy the error says paper, there isn`t any jam, I have tried turning it off, it still says paper jam. Help
There must be some piece of paper or other small material upstructing the path the paper takes and must be thouroghly cleaned to acheive maximum result.
Feb 11, 2010 | HP 190 Copier
Lexmark X6575 All-In-One InkJet Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
