HP LaserJet 2605DTN Color Printer Logo
Posted on Aug 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lazer jet 2605 prints perfect in middle of a4 but edge is very faded
Anonymous
Level 2:
New Friend:
  • Expert 105 Answers
  • Posted on Aug 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
105
Questions
0
Helped
21169
Points
332
How to fix text from printing unevenly as if the roller was not rolling consistently?
Sorry, I don't have one. Mine was a different problem; incompatibility between my old hp desk jet 5650 and my new Mac Book Pro. Just needed a newer printer!
When something like what you describe happens it is because the cartridge is dry; I change the cartridge.
Fade print
I would recommend removing the cartridge from the printer and holding it level. With this done shake it gently from side to side to level out any ramped toner inside the cartridge. Then re-install and run off a few pages.
If this does not help and you are getting to warning that any other components/consumables are nearing the end of their life then it is likely to be a faulty toner.
No longer printing in black
Check out black ink level? If good do a hard reset of printer along with a software reinstall. If that does not resolve the problem you may have a defective print head or just a bad
black cartridge since on may HP units the print head is built into the cartridge.
Brand new HP Colour Laser Jet 2605 printer prints a thick black line down the center
Print a cleaning page. If this does not solve the problem replace the black ink cartridge.
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
Install HP Colour Laser Jet 2605 printer
Use the bundled disc to install the drivers. If you do not have Vista drivers with it, you can download them from the hp site
My printer is printing colour red faintly, the toners are new and genuine. it also takes some times before it starts printing.
Sherry, in all probability it is the "scanner assembly" HP can fix this for $279 in the US using HP Express exchange 1 day ship, this was the result of their active chat. I am having the same problem and am going to dismantle the printer myself to see if I can't clean the scanner mirror myself. If you search the following words on google you will find some info, fading red tones laser jet 2605, one of the first results is a page on the HP site specifically on laserjet printers. I wish I had a quick fix that would help; however, a new cartridge won't help!
8helpful
2answers
MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
1helpful
3answers
Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
k24674
Grand Canyon Tech
Grand Canyon Tech
