Question about HP LaserJet 5200 Printer
Hp laser jet 5200 paper jam in fuser unit - HP LaserJet 5200 Printer
  • 1,218 Answers
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Oct 15, 2010
  • 105 Answers
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
My hp laser jet 4001n has a paper jam and does not burn the tonner
please check fuser roller assembly.there is an problem with heater.
Jan 26, 2014 | HP LaserJet 4100N Parallel/Ethernet...
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
Printer problem
even a very small piece of paper (A small piece torn off a jammed sheet) can cause the sensor arm to stick in place giving a false paper jam. Double check the entire paper path (what is visible) using a flashlight.
Also, check for broken "flag" sensors. Basically a flag sensor is a small piece of plastic that is pushed out of the way when the paper is traveling through the unit. If one of these flags is broken it may display a paper jam error as well (The flag after paper travels through will drop back into the paper path.) If this is broken it will not trigger the sensor and thus the error condition exists..
Most likely you have a small piece of paper stuck inside the paper path somewhere.
Do not, I repeat do not use any sharp or pointed metal objects to remove any small paper from within the fuser unit, the fuser covers are very delicate and such poking and prodding will likely damage the fuser covers, causing bad print quality or drastically decrease the fuser life (a small tear will quickly render the fuser useless).
Hope this helps!
Aug 31, 2009 | HP Office Equipment & Supplies
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Hp laser jet 1020 paper jam and not printing... half paper inside of printer
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Dec 27, 2007 | HP LaserJet 1020 Printer
501 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
