Question about Sharp AR-207 Copier
Can the Sharp AR 203E Toner chip be reset? How? The cartridge of my Sharp AR 203E still have more toner, but it stop from copying. I already have used cartridges that still have toner. How can I use the toner left from the cartridges?
  • 3 Answers
I have sharp 203 showing code op what does that mean
Posted on Aug 19, 2011
Hi i refil the toner for my sharp ar-m207 and later the copier say add toner can not print or copy help my please
You have to replace the whole toner cartridge because there is a crum chip on the back of the toner cartridge. When the cartridge reaches empty and the copier says change toner the copier burns that chip so it can not be reused again.
Aug 24, 2011 | Sharp AR-M207 All-In-One Laser Printer
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Call for service u2-40 sharp ar 275
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as faulty, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 16, 2010 | Sharp AR-275 Copier
I have a sharp ar-235 what does call service code U2-40 mean
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
My copier sharp AR-161 is not working it's write
please change toner cartridge chip your toner cartridg is fail due to toner empty
May 12, 2010 | Sharp AR-160 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Copier says replace toner cartridge but cartridge has been replac
The "chip" was necessary to "reset" the electronics inside the refilled cartridges, to say that the cartridge has been refilled. Obviously, the chip did not properly do the "reset".
Your only hope: take the document, as a PDF file or a Microsoft Word document, copied to a USB memory-stick, to the local "big box" store, e.g., Staples, or Office Depot, and let them read the file from the stick, and print onto their printer.
Feb 02, 2010 | Sharp AR-M277 All-In-One Printer
My sharp AR-203E photcopier is flashing a number then what appears to be the letter H, it had a paper jam but thats now sorted but it wont do anything!! help
on the control panel press clear button then interrupt button then zero button then interrupt button the display will change, then press 1 then 4 then start button then clear button (or power off) if you are blinking H then 5 it means you have had several jams in the fuser
Jan 07, 2010 | Sharp Office Equipment & Supplies
Sharp AR-207 Copier Logo
954 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
