Question about Asrock 845GV (P4I45GV) Motherboard
I have a m,b, asrock 845 presscot mothwer board cpu fan is running but not booting and not display .
    President:
  • 2,571 Answers
Are you getting any beeps. These can tell you what your problem is. Just google asrock beep codes
Posted on Aug 25, 2010
Asrock G31M-S No Display/Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
Dec 18, 2014 | Asrock Computers & Internet
No video from motherboard even with new video card
Dear sir,
if this board has AGP slot, try to use AGP card inspite of PCI display card .. second thing when u power up the board . short its crystal oscillator for 2 second during switching on ..by screw drivers..if if it will not provide display .
then open fan & reinstall CPU .. if cpu is OK ( only can be tested on other board ) ..then something is wrong with Northbridge ../ or power supply mosfet of board if fan is not running ..
Regards
raj
Jan 26, 2011 | Asrock P4i65G Motherboard
I HAVE ASROCK MAKE INTEL CHIPSET MOTHER BOARD AND SOUND CHIP IS CMI9739A AND I REQUIRED ALL DRIVERS
plz follow these links(all links have a different different drivers) and choose ur operating system, and get the drivers, i hope u will get the solution.
http://www.asrock.com/MB/download.asp?Model=K7S41GX&o=XP
http://www.asrock.com/SUPPORT/CPU.asp
http://www.driversfix.com/Asrock_Motherboard_drivers/cat16/cmp78.html
Nov 06, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Jan 10, 2009 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
Asrock 845GV (P4I45GV) Motherboard Logo
95 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
