Question about Whirlpool Refrigerators
Water not coming through to ice machine - Whirlpool Refrigerators
Check your water line to the ice maker and see if it's frozen, use a blow dryer to heat up the intake tube and clear the frozen ice that is stopping the water flow. You can also leave the refrigerator/freezer doors open for eight hours to deforst the frozen line. After you defrost it and you still don't get ice then replace the failed water inlet valve
http://www.thriftyfun.com/tf24835944.tip.html
Posted on Aug 25, 2010
Youtube
taste the water coming out of the filter ? should come from a cold water line, not the hot water line, funky smells and tastes come from your hot water heater. and I don't want to hear the hot water freezes faster bs. hot water heaters are full of stuff you don't want in your body. So if the water tastes ok....
sounds like you need to give the entire fridge a defrosting, clean it up real good. also have baking soda ready for monthly treatments, just crack a box open and stick it int the fridge or freezer.
These ice machines never did make quality ice as they just freeze still water, witch make cloudy, less than savory ice.
If you are a big ICE lover like me. a under the cabinet flowing ice machine is the best ice, as it last the longest(almost clear) and has no ill flavor.
Jay the pool pump guy longwood
Jul 25, 2014 | Whirlpool Refrigerators
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Ice machine working but very slowly
I am not sure about the commercial ice, but I would check to make sure the water tube that goes into the maker does not have an air bubble in it. That can cause the water not to come into the freezer to make the ice cubes.
Aug 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My model AM-50bae ice machine has water in the storage bin,what can I do?
check the bottom of the bin for a drain spout. The drain line may be clogged allowing the water to build-up in the bottom.
If the water is coming down from the ice machine itself, you will need to open up the machine and look inside. Check to ensure the cube guides have not come out of place, that the sump is not overflowing with water, and that there are no loose, leaking, disconnected, or busted hoses.
Jun 06, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Our jenn-air side by side refrigerator with ice-maker has a problem. Quite often it makes a buzzing sound which seems to be more frequent than is normal. There is water inside the freezer which solidifies...
Good day,
You'll need to isolate the problem. Shut the water off to the machine to eliminate the ice maker as an issue. Clean up any mess left over and restart the machine with the ice maker set to the off position.
Run for a few days to test the quality of the cooling capacity of the machine. If it tests O.K. then the ice maker situation can be addressed.
May 10, 2010 | Refrigerators
We have a new out of the box machine and the water isn't getting into the water tank. the line has water and pressure, i primed the line, placed water in the holding bin (which produced ice) but the water...
if you put water in the tank, water won't come in until the tank is low. plus, it should be cold water. the manual should provide you with information about any plug or what needs to be done before making ice. the manual is invaluable.
Jun 30, 2009 | Franklin Industries Franklin Chef FIM200...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
27 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
