Question about Rinnai Water Heaters
Hi the electricity was cut to install a heat pump today. Electricity back on and everything else running except hotwater. Pushed the on/off button inside which usually gets it up and running to no avail. Not sure if I need to do something on box outside which I have checked is on.
    Novelist:
  • 120 Answers
I'm going to run through the obvious first so stick with me. Make sure the heater outside is plugged in to the power point and that it is switched on. Try something else in the power point to make sure you have power there. If you have no lights on your controllers inside then obviously you have no power to the low voltage side of the heater. If you have power to the powerpoint but still nothing doing with the heater then unfortunately you have a fault on the heater. There are no resets in your heater. It could be messing around with the power supply has blown the surge PCB , the main PCB or on older models the transformer. I Hope that the obvious solution fixes your problem because otherwise you need a technican and likely some new part/s.
Posted on Aug 26, 2010
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
Tip
Rest Electric Hot Water Tank Thermostat
I understand that you need to reset your hot water tank thermostat. Here are some instructions for you to follow with visual aids on what you are looking for and what you need to rest.
First you must locate the thermostat in order to rest it. There are usually two service panels on a hot water tank. The service panels look similar to the ones in the picture below.
justinbur167.jpg Once you locate the service panel(s) you will need to remove the top on and locate the thermostat the reset should be in the top one. You will be looking for the button that is located in the middle of the thermostat. This button will need to be pushed down firmly. The rest button is often red however; it comes in many different colors, shapes and sizes.
If the thermostat rest automatically pops back up then you will need to replace the thermostat. If you do not hear the heating elements heating up like in your coffee maker her the noise of the elements heating. You may have a bad element or thermostat of even both may be bad. The cost of rebuilding a hot water tank is cheap compared to replacing so I would suggest rebuilding. This is a pretty easy task that you can also receive help from FixYa for.
Hot Water Image: visualdictionaryonline.com: Copyright QA International 2011
http://www.bing.com/images/search?q=electric+hotwater+tank+&view=detail&id=947D2952ACE0C75D1DCEDB6216D99F764F1F2DB1&first=31&FORM=IDFRIR&qpvt=electric+hotwater+tank+
on Apr 09, 2011 | Water Heaters
No hot water - the light shows red. It has had problem in the past months but cutting the power off and back on seemed to reboot the computer. This time the light stays red.
Before calling service technician:
Click following link, the click product, then scroll to page bottom to tab that offers technical literature, and download service manual and operation manual.
http://www.hotwater.com/water-heaters/residential/hybrid/
Read the required installation and maintenance protocol to see if air filter has been cleaned regularly, or the condenser coil might be dirty.
Required maintenance can be done by service tech recommended by AO Smith.
Contact AO Smith to find trained person, and next time, do not install expensive water heater since all savings disappear with service issues.
Gene
h
Sep 08, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
I just installed a water heater about 11:00 am today but still do not have hot water what could it be
1) Many times people turn ON the electricity before the tank is filled with water.
This instantly burns out any element that is not submerged in water.
If the upper element is burned out, the lower element may be good, but the way the thermostats work, the upper element must heat top of tank before power is sent to lower element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) My new electric water heater had same problem, and the red reset button, or ECO, was tripped on upper thermostat.
Open cover and check reset.
3) I will be here for the next several hours, add a comment and I will help further
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Nov 05, 2010 | RELIANCE ELECTRIC WATER HEATER
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
I have a 50 gallon electric water heater..trying to fix a leak elsewhere in the house we had to shut off main valve,turned back on no hot water,,reset breaker and reset button worked fine,but no today no...
If you're having to reset the breaker, then most likely you have a bad heating element. Usually the bottom element burns out first, however if you had the water off, and the level dropped in the tank, the heater might have come on without water in it. This will cause it to overheat and burn out. Now when you turn the breaker on, the current is going to ground, tripping the breaker. If you are handy you can replace them, but be sure water heater electric is off or disconnected, and then drain water below the element level. While you're replacing one element replace them both.
Oct 13, 2010 | Whirlpool Water Heaters
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Water Heaters Logo
309 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
