Question about Casio G-Shock G7100D-1V Wrist Watch
I want to know what is the default password for e-data memory
Watch says the memory is full and I cannot start the time
Once you reset the watch then connect to PC and on Garmin connect you should see the memory then clear back down. Make sure all files when plugged in are either backed up or cleared.
Mar 31, 2014 | Garmin Forerunner 110 GPS Heart Rate...
I deleted pictures from my gallery can i recover from sd card
Try also following software for windows photo recovery softwae http://www.comparisonandreviews.org/photo-recovery-windows.html
for mac phot recovery software http://www.comparisonandreviews.org/photo-recovery-mac.html
Dec 13, 2013 | Samsung Galaxy S III S3 16GB AT&T
How does the log function work and how do I recall the information about each dive?
I had the same problem when I got my watch. It was resolved with help user manual on the page 72.
Conditions for Storing Log Data in Memory>
• The log number and log data are stored in memory when
the watch remains at a depth of more than 1 m (4 ft) for
3 minutes or more, or it remains at a depth of more than
8 m (27 ft) for 1 minute or more.
It's not a bug it's feature :)
Jan 26, 2011 | Citizen Aqualand JV0030 01E Watch for Men
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
Forgotten password on mmc mobile memory card
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Apr 15, 2010 | Rado Xeramo High-Tech Watch
F55 watch is frozen and cannot get back to main
HI dyer_christi
Most of these watches hold there memory whilst the batteries is still in. Unfortunately the best thing to do is to remove the battery and reset all data! I know this means you loose the hard work you have done, but I do not know of any other solution? Are you capable of changing the battery or would you like some help? I can provide additional assistance with this if you'd like. You need a small philips head screwdriver, some small tweezers and a clean bench with a few mins (say 30). if you'd like I'll help you through
Jul 15, 2009 | Polar F6 Wrist Watch
Remove alarm schedule
go to each alarm and press the upper button on the left side to disable the alarm
Feb 26, 2009 | Casio E-Databank EDB6101C Wrist Watch
Casio digital diary
HI,Im sorry i dont know the solution for this..but actually i have the model as your SF-9350 and dont know know how to operate it i mean few thing..plus i have also forgetten my secret password,can you help me out??
Feb 16, 2008 | Casio Watches
Forgotten Password
Try taking the battery out, and leave it out for a while.
NOTE: All memory will be deleted.
Aug 23, 2007 | Casio G-Shock G7100D-1V Wrist Watch
Casio G-Shock G7100D-1V Wrist Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
