Question about Polaroid FLM-3734B 37 in. LCD HDTV
When you turn the tv on it makes a little noise and takes a little while for it to warm up.
    Genius:
  • 1,622 Answers
A common problem for these is bad capacitors in the power supply. Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9x capacitors that are bulged/ doomed shaped on top usually are valued at 3300uf 10v any that have bulged or leaked a brown like substance should be changed.This will cure the problem as they overheat being sat next to a heatsink that gets very hot.
Do change them for the same 3300uf but a higher voltage.\
Thanks for asking fixya, with this the problem will be solved.
Posted on Aug 25, 2010
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The tv picture is going out. It turns off and on
Chinese piece of ****. It is what the USA deserves.
Mar 29, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Noise from engine
Check your belt. Belts will whine when they're worn, cracked or glazed. I hope this was helpful. It's not normal. Take care and God bless.
Bryon
Feb 05, 2010 | 2004 GMC Envoy
High pitched sound comes from tv ---no controls on tv work--you have to unplug it to get the high pitch to go away
Is this a tube tv?IF it is the Flyback tranformer have a little still bar tranformer hight current volt make that noise take off the tv cover put some glue on the little steal bar should stop the noise or lower it very good.
Aug 12, 2009 | Televison & Video
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Tv taking long time to come and when come on making humming noise
. These are the caps I replaced they where only a little swollen I was worried if they where even the problem but I changed these three and was very happy that my TV is now working like new again the two top ones I replaced with 1000uf 16v the lower one is 1000uf 35v ok well I hope this helps ya
Nov 28, 2008 | Polaroid FLM-323B Television
Philips projection tv have sound,no picture
wha is the make and model of your set
Nov 01, 2008 | Televison & Video
RCA HD52W59 HDTV.....will not turn on, makes a weird noise
you need a new flyback. Its a very easy repair you need flyback 259296 and you can get a new replacement at the following link and they explain step by step how to replace it. Heres the link
http://servicemanuals.vstore.ca/
Sep 04, 2008 | RCA HD52W59 HDTV Projection Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
18 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
