My Zanussi zwf 1221 w washing machine stopped working last night. The lights are on but they are get stuck on the start/pause light & the washing light. No matter which programme I put it on or which spin cycle I put it on, the lights stay the same & the machine does not start washing. The door is also locked shut during all of this. After a while, the end light flashes twice then goes off for a short time & repeats this again. Can you help me?
  • James Logue Aug 25, 2010
    Thanks for the reply.
    Water is collecting in the drum.
    How do I check the water level sensor
  • Washing Mach... Master
  • 17,130 Answers
What is important is for you to confirm are some of the following tips.
1..If there is no water collecting in the drum then the inlet valve is not switching ON and so might be faulty .Unless water flows into and is sensed the program will not advance.
2. If there is water collecting but is not switching off, the the water level sensor is faulty, if the water level sensor does not sense and switch the program will not advance, so checkthis out.
3. If the water sensor cuts off the valve but down not engage the motor, then check motor, maybe the motor or the capacitor of the motor is faulty. If function does not switch power to motor, then the controller is faulty.
4. The above sequnce must work correctly for the program to go forward.
So make sure that the voltages are present at all these stages to the concerned component or else the specified component is defective . If none works the timer controller unit is faulty.
Hope you follow these steps.
Posted on Aug 25, 2010
  • Donald DCruz
    Donald DCruz Aug 25, 2010
    There is an over flow tubingg which connects to a device which is an activated pressure switch.
    Look carefully in the drum holder assembly if possible from underr the unit..
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Zanssi washing machine ZWF 1221 W will not spin
Do you realise there is a law I understand that says for 6 yrs the goods should be fit for the purpose you bought them for. Look at this "your rights " & go tackle the store you bought the machine from.
http://www.guardian.co.uk/money/2006/jun/01/yourrights.legal4
Jun 21, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
