Question about Microsoft Xbox 360 Console
Completely erased 250gb hdd,no partitions,will only recognise as usb storage,how do i fix problem without using garbage bin solution
    Guru:
  • 374 Answers
Hello
You will need to do a full reformat of the HDD to get it back to its shipped state(you will loose EVERYTHING so back up things you still want on a USB stick or memmory card)
her goes some instructions:
To format a storage device
  1. Start your Xbox 360 console without a disc in the tray.
  2. On your console, go to "my xbox", and then select "System Settings".
  3. Select "Memory".
  4. Highlight the storage device that you want to format and press the "Y" button
  5. Select "Format"
  6. If asked put in your serial number but read everything to be sure its the action you want.
be sure to do this without anything in the USB or a disk in the drive.
Let me know how it goes and if you have any questions.
Posted on Aug 25, 2010
My computer does not recognise simpletech 250GB HDD drive when connected. The lights glow only. Earlier I had used this on my TV. Could it be that the system got corrupted
Buy an external USB hub that has an AC power adapter.
Your computer is not providing enough power to spin up the drive.
A self powered hub will provide the necessary power. 7 Port USB 2 0 HUB AC Adapter Monoprice com
Mar 10, 2015 | SimpleTech SimpleDrive 250GB 3.5" USB 2.0...
My 1tb elements external drive is not recognised on windows 7
I'm guessing the HDD needs to be reformatted. To reformat... ALERT THIS WILL ERASE EVERYTHING ON YOUR HARD DRIVE. if there is import information that is not backed up, back it up on a computer that recognizes the drive.
Go to control panel in the start menu, then to system and security, then Administrative tools, then computer management, then storage, Disk management,
This will list all storage devices that are connected to the computer. Based on the names you should be able to tell which one is the western digital. Right click, format and follow the formatting wizard. Format the drive as NTFS. Allocate all available space to 1 NTFS partition unless you would like multiple partitions.
Oct 03, 2011 | Western Digital 1TB WD ELEMENTS USB...
I can't find my Hitachi 250 external HDD in my computer.Although i can see it on the Devices and Printers,but also there is no option of open it or do anything on it. Goodluck
Your external hard drive has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click Administrative Tools.
4. Double-click Computer Management.
5. Select Disk Management under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hdd.
Thanks for using FixYa.
Mar 09, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Windows 7 does not recognized it
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
Good luck and thanks for using FixYa.
Dec 27, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Seagate HDD Harddrive 320 GB:How To Get Data Recovery?
Connect HD in another computer as a slave drive.
Nov 28, 2010 | Seagate Computers & Internet
My laptop suddenly will not recognise the seagate device,
Download "Testdisk & PhotoRec 6.10" from www.download.cnet.com
and follow the instructions. TestDisk is a powerful data recovery utility. It was primarily designed to help recover lost partitions and/or make non-booting disks bootable again when these symptoms are caused by faulty software, certain types of viruses or human error (such as accidentally erasing your Partition Table).
Once you install the program, you can find step-by-step instructions in google. This program is really easy to use and will fix your hdd.
Feb 27, 2010 | Seagate Free Agent Go Small 12 GB USB...
PS3 hard drive transfer
seagate eSATA 250gb hard drive, the PS3 uses a laptop sata drive, how you get this to work?
You have basically have 2 options you could try:
Use Linux for retrieve the data of get the original mainboard back.
The PS3 + HDD bonds together, so if you were to save stuff eg, online purchases, you need to have the same account for max of 5 downloads to 5 differenct units, BUT you cannot just swap out the HDD and expect it to work. The PS3 has a feature to backup from internal directly to an external USB hard drive but online limited to data, most purchased movies and/or MP3 will not be transferred, it sucks.
You can have as much HDD you want but only YOU can use them , cannot be shared with another PS3. I hope that helps a bit
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Can i format sata hdd without loseing my files
partition magic may do it, but chances are not. in order to change a filesystem, you have to erase all data to avoid compatibility issues. some file systems have file size limits or even file name character limits and doing a format without erasing the data can corrupt the drive to the point where the data is unable to be recovered. I always recommend backing up data first and would never even try a format without backing it up.
Jun 10, 2009 | Fanner MASSCOOL 3.5" PATA and SATA hard...
Partition external 250gb drive
why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Aug 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
HDD not recognised
HI Your Hard Drive is previously formatted and have done different partition provided by your previous machine where you took this hard drive from. Use "The Partition Magic" Software, it will help you to fix and repartition your hard drive in the new format. I have this problem before and now my hard drive can connect with any computer. The key in this issue is any hard drive goes with the original machine has been formatted and do its own partition from manufacturer so if you take it out later for use with other machine, you will need a software to completely rearrange the new partition in universal format so other computers can recognize it. This manufacturer purpose to protect your data from hacking, stealing once you take it out from the original machine. That is why when you connect it to other machine, this hard drive will not be recognized. I has this partition magic software and can make you a copy so you don't have to buy it. Just read the instruction and you can fix it for both 2.5" and 3.5" HD. Please email me at joe_dao2003@yahoo.com and provide me your mailing address, I can send the copy software to you. Regards, pingping
Jun 15, 2007 | Hitachi Deskstar T7K250 250 GB Hard Drive
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
