WASHER SPINS BUT DOES NOT DRAIN COMPLETELY. IT IS A NEPTUNE FRONT LOAD WASHER
    Genius:
  • 1,073 Answers
What is the model number of the washer
Posted on May 05, 2008
Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain maytag neptune washer MAH-3
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes washer does not drain completley
Clear the filter and the pipes between it and the pump, tip the machine back and look under you will see a black pipe from the filter to the pump. Simply remove the pipe and clear it and the pump while your there.
Aug 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Occationaly washings machine doesn't drain completely
It is a drain problem.Here is a link for more info related to this problem.
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
Dec 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
