Question about Refrigerators
What setting should the hotpoint frost free ff187e be on ?
  • 4,793 Answers
Forget "settings"get a thermostat and run the freezer at -18c and the fridge at +5 these are the ideal temps for storage and economy.
Posted on Aug 25, 2010
2 Suggested Answers
SOURCE: flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Posted on Sep 23, 2009
How to fix a hotpoint frost free fridge freezer
I would call a repairman . possibly the fan has worked loose on the motor shaft
Oct 08, 2015 | Total Micro HDP80CF72-PAN 80Gb Notebook...
Hotpoint ffa91 My frige is freezing everything I put inside it.
sounds like the door between the freezer and cooler is stuck open
Jan 23, 2014 | Refrigerators
Hotpoint ff187e
sounds like you have a bad contac on the wiring attaching to the socket but if this is a domestic refrig is a 115volt but the name plate inside will tell you for sure.
Oct 23, 2013 | Refrigerators
Hi, my hotpoint fridge/freezer FF187E its my fridge area not cooling and my freezer is working but starting too get ice around the sides and that.
sometimes its just easer to replace the defrost termination thermostat get a 55F for about 15.00 bucks and just change it, if it works thats the problem, if not, it may be the element or defrost timer
Mar 12, 2012 | Refrigerators
How to fix hotpoint ff187e the top of the fridge is not working and not getting cold
Hi
It's possible that the compressor is dead or not working properly. Also try to dust off the coils in the back.Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils ( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Also check the bellow link to get a useful article to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsstoppedcompletely
Please get back to us if you have further query else please accept the suggestion.
Apr 03, 2011 | Refrigerators
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Dec 08, 2009 | Refrigerators
Flashing lights on hotpoint fridge
Aug 04, 2009 | Refrigerators
Hotpoint frost free ff200e flashing lights and beeper freezer food defrosting
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Jul 05, 2009 | Hotpoint Refrigerators
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
