Question about Kitchen Ranges
We have had cooker 10 months was repaired after 2 months with new thermo coupling oven kept going out this has happened again in hour n half of cooking chicken went out 3 times dont no whether it is part of problem but children and adults in house suffering very bad headaches
    Problem Solver:
  • 3 Answers
This probably needs more information to solve. What kind of cooker? Do you have electrical problem/ or gas problems?
The headaches for everyone in the house is an issue you need to look into. If your stove is gas and you suspect a gas leak (something that is very dangerous and can cause headaches) you can start by asking your gas company for an inspection. This is usually a free service because they don't want people blown up in their homes. Headaches can also be caused by carbon monoxide. If you have an attached garage and let your car warm up inside, this can be the cause. A nearby garage can also cause that. You can check carbon monoxide levels in your home with a six dollar tester you can buy at any discount store. Finally, molds can cause the whole family headaches. Look for discolored spots anywhere water can gather -- under eaves, beneath sinks, and near your water heater. If the headaches continue, seek help from an expert.
Posted on May 05, 2008
Lincoln Impinger 2 Double Conveyor oven temperature unstable
It looks like a thermostat problem, but if the thermostat had already been replaced, remain to check the valve and the pressure switches.
When the valve is defective, gas will turn off and not restart, Check and eventually replace the pressure switch , but it can also be a control problem.
Let see if I can find support and repair in your area.
Oct 08, 2008 | Lincoln Conveyor Oven - 1133-000-A
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
The oven on my gas cooker will light but wont stay lit
Thermo coupling needs changing, unless you are Gas Safe, let someone else repair for you, its a common problem, shouldn't cost much, good luck , the Yeti
May 20, 2009 | Miele 20 in. KM405 Gas Cooktop
Kenwood cooker
It seems to me that your oven has a thermo couple which is faulty. this needs to be repalced. This part control the gas going into the oven if faulty it will go out.
Most ovens have ffd or fsd, however im fairly sure yours is a neither of these and is a thermocouple.. hope this helps..
Dec 24, 2007 | Ovens
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
3040 VG
I need a knob for a slow cooker 3040 Rival terragno@comcast.net
Oct 31, 2007 | Rival 3040-VG 4-Quart
LG Flatron monitor problem
It is often difficult to diagnose/repair an intermittent problem. It could very well be any of the circuitry and components inside: video interface, CCF Lamp, inverter, power supply. All of which would require that you open the casing and poke around inside and that you be familiar with electronic components & circuitries, soldering and use of a continuity/volt meter.
Doing so would void your warranty (being just a couple of months). Perhaps your best bet would be to seek repair/replacement of the monitor from your dealer/supplier and describe fully the nature and frequency of the incidence. It may be that when they test it will check good.
Should you choose to open it up yourself, post back.
Good luck and kind regards.
Oct 23, 2007 | LG Flatron L1750S 17" LCD Monitor
Mushy after less then 24 hours
It's not meant to keep in there for a few days. A few hours would be the max, say for a party for instance. When you are done with the rice, take it out and put it in your refridgerator.
Sep 12, 2007 | Zojirushi NS-PC10 5-Cup Rice Cooker
Kitchen Ranges Logo
118 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
