Question about Frigidaire FGR341AC Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
Clothes are getting stuck in the drum groove in front bottom section of front load dryer. There is a gap where the drum rotates under lint catcher. Dryer is level. Any help would be appreciated! [If this thing ruins another piece of wife or daughters clothing, I could be in trouble.]
  • 5 more comments
  • brayty May 19, 2008
    I have both problems a high pitched sound when the dryer is running and clothes are getting stuck in the bottom corner.
    There is a gap between in that corner also.
  • mugroot7 Oct 23, 2008
    I have same problem with clothes getting caught and tearing up while it turns.
  • shan3tea Mar 16, 2009
    I have had to throw away or try an repair several articles of clothing because a string or strap will get caught under lint trap and it just twists until it breaks
  • bharjeh Mar 28, 2009
    I have the same problem and my whites come out of the dryer with 2" black marks on them. Is there an online manual available to show me how to open and repair this?
  • jimmy8000 May 11, 2010
    when i turn on the dryer i hear a high pitch sound please help and how to fix the problem
  • Anonymous Mar 21, 2014
    clothes get stuck at bottom front between drum
  • Anonymous Mar 24, 2014
    THE DRYER LIGHTS BUT ONLY FOR GIVE OR TAKE 5 MIN THEN SHUTS OFF. THE DRUM REMAINS SPINNING BUT NO FLAME IS PRESENT. THEREFORE LEAVING MY CLOTHES STILL WET. WHAT IS LIKELY THE PROBLEM?
    Genius:
  • 1,028 Answers
Front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
Posted on May 06, 2008
The front drum seal does not need replacing on a new product, it is a manufacturer defect, and I hope they recall this model soon!
Posted on Nov 17, 2008
Drum gap
what is the model number?
Dec 09, 2012 | Kenmore 83142 Electric Dryer
Clothes stuck in drum
You might have a drum glide, felt piece, that has come off or unaligned itself from the drum. Contact Frigidaire for one and replace it. You have too much of a gap in the front and that is why your clothing material gets caught.
Jul 29, 2012 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Gallery model Gler341AS2 drum is sagging towards 6 o'clock and causes a gap that snags clothes. What parts need checking to find the cause of this?
seals on front and back, but drum rollers/glides here is a website, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Apr 17, 2011 | Frigidaire GLER341A Electric Dryer
The drum on my frigidaire Gallery dryer is tipped down , so there is a gap at the bottom and clothes get stuck in it. Can this be adjusted?
Suspect one or more failures of the drum front support bearings. Remove the cabinet top by removing several screws at the rear of the top, then pushing it to the rear somewhat which should allow the top front to lift up to allow removal of the front cabinet panel by taking out several screws on each side, then lifting the panel up to release it from the bottom. Once the panel is off, the support bearings should be mounted around the drum opening in the panel. Hope this helps!
Nov 20, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
Apr 10, 2009 | Frigidaire Dryers
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Fridgidare dryer problem
there is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Nov 16, 2008 | Dryers
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Frigidaire FGR341AC Electric Dryer Logo
886 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
