Question about Rockford Fosgate Car Audio & Video
Is the rockford fosgate punch p550.2 1 ohm stable?
duby1990
  • 370 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
jpenn1192
  • 58 Answers
SOURCE: Rockford Fosgate P2 12" cone
TRY GOING TO, SONICELECTRONIX.COM, OR WOOFERSETC.COM
Posted on Jun 18, 2009
  • 1114 Answers
SOURCE: when my bass hits, my car lights flicker.
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
Posted on Aug 20, 2009
  • 57 Answers
SOURCE: i need to wire up a rockford fosgate punch hx2 12"
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Posted on Jun 28, 2010
judd0081
  • 334 Answers
SOURCE: i just needed some help
Well i tried looking up that amp, but Fosgate sight is down. So assuming that the best power out of your amp is 2ohms off the bridged hookup, and the subs are 4 ohms per coil, the best way is to only use one side of each speaker and hook it straight the the bridge. Only using one hook up wont hurt anything, its just for giving you wiring options. And when adding up ohms of speakers, it goes like this. If you had two 4 ohm subs, that'll give you a 2 ohm load. If you hooked up all your hookups, it would be like having four 4 ohm subs, and would give you a 1 ohm load.
Posted on Jan 19, 2011
Can a rockford fosgate 500a2 run 1 ohm stable
yes, if you add a 1 ohm resistor to the negative terminal of speaker.
May 08, 2014 | Rockford Fosgate Punch 500a2 Car Audio...
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
WHATS THE BEST WAY TO WIRE 2 DUAL 2 OHM L5 15
Crutchfield is always handy for a wiring diagram.
Dec 12, 2017 | Car Audio & Video
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Need to know how many ohms this amp is
Safe down to 2 ohms, NOT a 1 ohm stable amp, it will be pushing it hard even at 2ohms but Fosgate's should be able to handle it providing that the install and all cables,wire,connections,etc. are sanitary!
Good Luck !
Jun 30, 2010 | Rockford Fosgate Punch 301S Car Audio...
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Wiring configuration 800a2
    3 ohms per channel or 6 ohms bridged are the only options. 3 ohms per channel is a better option.
    Apr 18, 2008 | Rockford Fosgate Punch 800a2 Car Audio...
    Car Audio & Video Logo
    50 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    seankane89
    Level 1 Expert
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
