Question about Acer Aspire 1640Z Notebook
Burning Cd Can i burn a cd on Itunes and use that same cd to add more song on later.usually when i used it once after it has completed the burn, i can not add anymoe songs to it
    President:
  • 2,712 Answers
Yes you can. Just choose multisession disc..
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
How do I burn copies of cd-r and get the text to show up as the music is fine
When you burn the cd to your MP3 are you online? I notice when I'm online when I'm burning cd to my iTunes or MP3 the name and songs come up. If I'm offline it show the tracking not the song.
Feb 13, 2015 | Audio Players & Recorders
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
Downloaded new version of itunes now i cant burn cds
you have to set the process up again Burning CDs in iTunes is easy and requires no setup.
But if you are an advanced user, you may want to tweak the settings a bit. Here's how you can set CD burning preferences in iTunes:
Open up iTunes on your computer. Click Edit and then select Preferences. Click the Advanced tab. Click the Burning tab within the Advanced tab. Set your preferred speed. From the drop-down menu, choose a burn speed for your CD burner. Choose a format. Audio CDs are for playing in your stereo or CD player. MP3 CDs can hold more songs, but need a special type of CD player to be read. Data CDs are for backing up songs, and can only be read by computers. Choose a gap between songs. By default, iTunes puts a gap of silence between each song. You can change this option from the drop-down menu. Use the Sound Check feature. This option will automatically adjust the volume on your songs so they will be the same volume on the CD. Include the CD text option. This will give the CD the title of the playlist to be displayed by a stereo or CD player that supports CD text. Click OK to save your preferences.
Feb 18, 2013 | Dell Inspiron Zino HD Desktop Computer...
Downoaded i tunes now i cant burn cds
you might have to set the process up again
Burning CDs in iTunes is easy and requires no setup. But if you are an advanced user, you may want to tweak the settings a bit. Here's how you can set CD burning preferences in iTunes:
Cannot burn audio cd with iTunes
Maybe iTunes don't want your burning their music. I'm not sure cuz I don't use Itunes, but if it works on others that sounds like it might be the problem.
Here I found the below on Apple's site.
Symptoms Find out what to do if you can't burn an audio CD using iTunes for Windows. Sometimes an audio disc may not burn as expected. Here are some things to check.
Resolution Update iTunes Download and install the latest version of iTunes for Windows.
Songs not authorized iTunes will stop burning a disc if one or more of the songs in a playlist were purchased from the iTunes Store but are not authorized to play on this computer. This message appears:
"Some of the files can not be burned to an audio CD. Do you still want to burn the remainder of this playlist? For more information on why some files can not be burned, click below".
There's more so click the link below and see why you can't burn your cd.
http://support.apple.com/kb/TS1436
May 09, 2012 | Dell Optiplex 755 Desktop Intel Celeron...
When I try to burn tracks to a CD itunes says that there is no burn software.
That is probably because the cd is already used or somebody canceled the process of burning the cd, also once you have started a burning process with the cd you can not use the cd over again so basically you need a blank cd make sure you check to see if the cd is blank before trying to burn the cd.
Nov 10, 2010 | Apple iTunes
My Cd burner is not burning a complete disk
the ans is simple tht burn the project again on an fresh cd and play it
Dec 20, 2009 | Toshiba Satellite M55 Notebook
Burning a disc
please 1st you install a burning software and then burn you disc.
Aug 11, 2009 | Apple iTunes
How to record from a website to cd on laptop
To burn cd/dvd you have to check :
1. Your laptop cd/dvd drive have what capability:
- cd writer = only burn cd
- cd writer/dvd reader(combo) = still only burn cd
- dvd writer = can burn cd, dvd single layer(4GB)
- dvd DL writer = can burn cd and dvd single 4GB and dual layer 8GB.
Other than those, is not possible.
2. Must have burn apps named:
- Nero
- Alcohol 120%
- other. search internet.
If you have them then using the apps to burn, just read the manual.
Koam114 is in Korean. I don't understand :)
But If you want songs from website, you should download it first.
Unless the site is giving you a step by step how to burn songs directly to your cd/dvd.
Once downloaded, would be easier to burn to cd/dvd.
Dec 26, 2008 | Toshiba Satellite L305-S5907 Laptop
Acer Aspire 1640Z Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
