Question about Norelco ReflexPlus 6853 XL Electric Shaver
After charging razor will not turn on no power how to open razor to replace battery if that is the problem
  • Norelco Master
  • 1,623 Answers
Most likely, the battery just needs to be changed. Open the shaver by removing the two screws near the bottom on the back of the shaver.<br /> You will find the correct battery at shaveroutlet.com. See link below<br /> <br /> <a rel='nofollow' href="http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html">http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html</a>
Posted on Aug 27, 2010
Testimonial: "thank you for the information. only on thing what type of tool is used to remove screws. They are not regular screws"
  • shaveroutlet.com
    shaveroutlet.com Aug 27, 2010
    you can use a small flat screwdriver or you can buy a tool at shaveroutlet.com. See link below
    http://shaveroutlet.com/screwdriver-acce...
MY RAZOR QUAD IS CHAREGED BUT WILL NOT RUN
I have exactly the same problem and it started right around the time the "gracious" 90-day warranty period expired.....
The battery lights had been on for days, indicating a full charge, but nothing happens when turning the throttle. Battery housing is very cumbersome to open, but I'll try to disconnect the battery next.
Jul 22, 2014 | Razor Dirt Quad Bike
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Jun 21, 2014 | Electric Razor Pocket Rocket Ride-on...
No power
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Apr 21, 2014 | Razor E100 Electric Scooter
Wont charge tryed a new charger think its the battery can i replace the battery ?
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
Dec 30, 2010 | Razor E100 Electric Scooters Red
I have a razor e200. Nice physical condition. Garbage picked. Light on throttle lights up next to the 24V label. No power when throttle is open. No engine noise. power switch is on. reset button is...
Charge the batteries. If still no power than replace the batteries because they are dead. The batteries in the scooter need to be kept charged. If the scooter has not been charge in two weeks to a month and over. They are probably dead and need replacing. Find replacements at razor.com
Jul 31, 2010 | Razor E200/300 Electric Scooter Battery
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Norelco ReflexPlus 6853 XL Electric Shaver Logo
99 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
