Question about Dyson Vacuums
In attempting to use the tools facility on my Dyson DC27 Animal vacuum cleaner the extending tube failed to fully extend as normal and required quite an effort to get as far as it did. I eventually managed to get into the release mechanism to allow the arm to fully extend as expected and allow access to releasing and reconnecting the flexible hose and the main handle. I discovered a small (1/2" x 1/4" approx) spring within and a loose plastic collar. After a few attempts to re-use the spring by setting it onto a small nipple on the said collar without 100% success, in clicking the whole apparatus back together the spring has re-emerged and I cannot release the handle from its fixed position even though the extender now seems fine. Can you guide me into how to release this handle and also where to put the spring when I reassemble. Is there a schematic diagram available for me to view. I am obliged. Alan Powell
SolutionGuy
  • 331 Answers
SOURCE: fitting a new control switch for the fan oven (model number 10450G)
Sesspod, 2 things... 1.) Pull the oven out and look on the back of it, there may be an envelope back there containing a technical data sheet which includes a wiring diagram. If not on the back, then possibly under the cook top. It is somewhere on your oven, sometimes the hard part is locating it. If you can find it, look closely and you'll see the wiring color and location is labeled. 2.) If you can't locate the tech data sheet, can you post a good macro picture of the back of your new switch so we can see what you're dealing with.
Posted on Aug 11, 2007
SOURCE: RE: f5 fault code; kdrp407hss
Solution!!! The hinges that Kitchen Aid uses are the problem. If the door is opened quickly & bottoms out, the steel in the hinge bends a little. So when you go to close the door it won't close all the way.... which causes problems with the latch , latch switch, oven cleaning, etc.
After taking apart the door several times I realized the hinge can be "fixed" without even removing the door. Follow the directions in the user manual for door removal... after inserting the little metal hinge stops (a drill bit or nail will work) Close the oven door till the stops won't allow it to close any further.....then gently but firmly, push forward. This will bend the hinge back to original shape. Remove the pins...Voila!!!
I wish kitchenaid used hardened steel or a thicker hinge....then this wouldn't happen.
Posted on Apr 16, 2008
  • 360 Answers
SOURCE: How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Posted on Feb 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
  • 134 Answers
SOURCE: Lens jams when extending or retracting
This is either due to a cracked internal roller or a cracked/broken internal cam. The lens will have to be sent to Tamron for repair.
Posted on Apr 21, 2009
I have lost the top to the filter on my Dyson, DC59 GT9-US-FJC3318A. Will you help me get another?
Variant Parts - Dyson
https://www.dyson.com/parts/variant-parts.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Dyson parts for DC59 Animal. Carbon fiber brush bar $22.99 Replacement Carbon fiber brush bar assembly for your Dyson DC59 vacuum cleaner.
Dyson Vacuum and Fan Replacement Parts - Official Site ' Dyson.com
www.dyson.com/parts/select-variant.aspx?category=Cordless
  1. Cached
Find spares and replacement parts for your Dyson vacuum or fan. Select your machine model to see a full ... Dyson Hard DC56. Dyson DC59 Cordless Vacuum ...
Spare parts for DC59 Animal - Dyson
https://www.dyson.co.uk/spares/variant-spares.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Image of Soleplate rollers Soleplate roller pack £1.50 · Image of Wand assembly Wand £55.00 · Image of Crevice tool Crevice tool £10.00 · Dyson Combination ...
Dyson DC59 / DC62 Animal Vacuum Cleaner Parts
www.partswarehouse.com/Dyson-DC59-DC62-Animal-Cordless...s/6871.htm
  1. Cached
  2. Similar
Dyson DC59 / DC62 Animal Cordless Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse.
Genuine Parts and Accessories for the DC59 Dyson Cordless Vacuum ...
https://www.dysonspares.ie/index.php?route=product/category&path=66_285
  1. Cached
Genuine Parts and Accessories for the Dyson DC59 range of Cordless Vacuum Cleaner. owerful handheld vacuum which boasts a brushless switched reluctance motor. It is small, light and powerful. Dyson DC59 Google Search
Dec 26, 2016 | Top Vacuums
How can i extend operating time on dc59 vacuum cleaner it only operates for 8 minutes, can i use a second battery?
2nd battery does not seem to be a viable option, reduce the suction power if u require less and it should work for 25 minutes approximately. (hope u know it automatically stops when dust the cup is full)
Jun 03, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
Wand will not pull out
Hi Colin, it's Jack at Dyson.
DC27's wand should release from the machine easily, and disengage from the body of the machine when it's fully extended. If it seems to be jammed in place, it's possible there's a blockage within the hose which is preventing it from extending.
To resolve this, open the clear U-bend and check for any obstructions.
This should help, but if you continue to have difficulty you're welcome to get in touch with the Dyson Customer Helpline for further assistance from our experts. We can help you check if the mechanism for the wand is damaged - and if a replacement part is needed, we can confirm whether your machine is covered under the Dyson warranty.
You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 06, 2015 | Dyson DC27 Bagless Upright Vacuum
My dyson dc14 animal is stuck extended and won't go back in:-( Every time I do the hoovering the pipe comes out. Please help
if it's like mine.... the extend metal tube can only come out when the recept tube is clicked and attached.
hope it helps
Dec 10, 2014 | Vacuums
How to clean filters for dyson vacuum cleaner
Hi Seema, it's Jack at Dyson.
DC27 Total Clean has two filters, engineered to last the lifetime of the machine in normal use. These should be washed at least once every 3 months using cold water without detergent, as shown in the video below. Allow at least 24 hours for both filters to dry completely before replacing them.
I hope this helps, but if you'd like any further guidance you're welcome to contact us directly by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Sep 08, 2014 | Dyson DC27 Total Clean Vacuum Cleaner
MY DYSON DC27 TOTAL CLEAN VACUUM CLEANER HAS AIR BLOWING FROM AROUND THE BOTTOM OF THE DIRT BIN. IS THIS NORMAL
Hi Pamela, it's Jack at Dyson.
Underneath the clear bin is the exhaust outlet, where clean, filtered air is returned to the room after passing through the machine. This is totally normal and part of the machine's design.
I hope this clears things up, but if you do have any further questions please email askdysonUS@dyson.com with your contact details, and one of our experts will be in touch as soon as possible. You can also find help online by visiting www.dyson.com/support
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Oct 24, 2013 | Dyson DC27 Total Clean Vacuum Cleaner
How do I change brush bar on dc27
Thank you for your inquiry. We recommend the DC27 brush bar only be replaced by an authorized service facility. Please call us at 0800 298 0298 so we can provide further assistance.
Best wishes,
Jessica
Jul 09, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My DC27 nose won't go down, I've put my foot on both sides & rocked it back but there is no movement - PLEASE HELP!
Hi Phil,
I'm sorry to hear you're having difficulty reclining your DC27. If the machine seems jammed and you can't detect anything causing this, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can provide further assistance.
We'll look forward to hearing from you.
Kind regards,
Jack
Dec 03, 2011 | Dyson DC27 Bagless Upright Vacuum
How do you release the wand when it is extended?
For information on removing and replacing the wand on your DC14, you might find it helpful to refer to the user guide supplied with your cleaner. In case you don't have it to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
You can also see further information on using the hose, wand and dusting tools in the Support section of our website:
http://www.dyson.com/support/help.asp?article=527&product=DC14-ANIMAL_US
If you have any more questions about using or maintaining your Dyson cleaner, please get in touch with us directly so one of our experts can provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON.
Kind regards,
Jack
Dyson Customer Service
Jul 31, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I just received a DC 28 animal vacuum and I cannot pull the extension wand out. I see the button to make the wand go up out of the hose, but I cannot figure out how to release the handle from the vacuum. ...
The Quick-draw Telescope Reach wand on your DC28 is designed to detatch from the cleaner automatically when you extend the wand to it's fullest extent. When you replace the wand on the cleaner, the wand will retract automatically down inside the hose. The button on the rear of the wand which you mention will separate the end of the hose from the wand, so you can use the hose without the wand attached when cleaning in tighter spaces. You do not need to press this to extend or retract the wand.
If you have any further questions about using or maintaining your Dyson, please see the user guide supplied with the cleaner, or visit www.dyson.com and click on 'Support. If you'd prefer to speak to one of our experts directly, you can call us free on 1866MYDYSON.
Kind regards,
Jack
Jun 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
