Question about Autodesk AutoCAD 2004 for PC
Error [9.1.4]. is occuring in my system in AutoCad 2004. How to rectify it
2 Suggested Answers
SOURCE: AutoCAD 2004 for PC: Are AutoCAD 2004 and Windows 7 compatible?...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Posted on Dec 06, 2010
Open the autocad 2004 show in error fatel error
We'll need some more info please. What OS and such will help.
Jun 02, 2011 | Autodesk AutoCAD 2004 for PC
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 on windows 7
Autocad 2004 is not compatible with Windows 7. Use a newer version.
System Requirements
For 32-Bit AutoCAD 2011 @
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=13784795
Aug 09, 2010 | Autodesk AutoCAD 2004 for PC
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
May 18, 2010 | Autodesk AutoCAD 2004 for PC
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2004 for PC Logo
470 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
