Question about Adobe Photoshop 7.0 for PC
How to install adbe photoshop 7.0 for pc - Adobe Photoshop 7.0 for PC
I canNOT find the 24-digit serial number
Posted on Aug 28, 2010
My alcatel is asking for an adb sideload. How do I do this?
Probably every Android power-user at least once in his life used ADB - Android Debug Bridge. It is a versatile command line tool that lets you communicate with an emulator instance or connected Android-powered device. Using ADB shell commands gives you additional control over your device and sometimes it can save your device from being bricked (example: How to: copy ROM zip file to the freshly wiped device). You can find some more basic information about ADB here.
How to: copy ROM zip file to the freshly wiped device. The main difference is that ADB sideload works only with recoveries based on Jelly Bean source or newer. I believe that ADB sideload was created to simplify the process of flashing/restoring Android update.zip packages.
Keep in mind that while using ADB sideload, the regular ADB shell won't work. To be able to use SIDELOAD mode make sure you're running latest ADB drivers from the Android SDK (Platform-tools). Here are the simple steps you need to follow to flash update.zip package using adb sideload mode (based on stock Android recovery):
  1. Place the ZIP package you want to install in the same location where you keep ADB drivers - adb.exe, AdbWinApi.dll and AdbWinUsbApi.dll (usually it's SDK\platform-tools)
  2. Make sure you have USB debugging enabled in Settings > Development on your device
  3. Make sure your phone drivers are installed on the PC you're going to use
  4. Boot your device in recovery mode (Android logo with a exclamation mark) and connect your device to PC
  5. Hold down "power" button first, followed quickly by "volume up" button. You should now see the recovery menu
  6. Use the volume up/down keys to select "apply update from ADB," then press power to select it
  7. Open a command prompt on the PC (cmd.exe), type and confirm with ENTER:
  8. cd /d <adb.exe location> (for example: cd /d c:\SDK\platform-tools) or you can open your SDK/platform-tools folder, then press SHIFT button and the right-click mouse button and choose "Open command prompt here"
  9. adb sideload <filename>.zip (for example: adb sideload update.zip)
  10. The zip package will begin installing. When it's done, select "reboot system now."
How is that different from the alternative method? You don't have to manually create the proper folders structure, push the file and later install if from inside the recovery menu. The result is basically the same, because ADB sideload is also transferring the zip file into the device internal memory and later it automatically begins the installation procedure. However, it works only with recoveries based on Android Jelly Bean source.
May 16, 2015 | Alcatel Cell Phones
How to hard reset my supersonic tablet
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website;
www.adbdriver.com/downloads/or click on link below for direct download.
ADB Driver Installer (9.22 MB)next, install the ADB driver then you will see a USB root on notification area on your PC.
No comment next, download the fastboot click on link below;
https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
next, command prompt will open and you need to type these commands;
This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
that is all; your tablet will be completely restored...
thanks and good luck.
Jul 03, 2014 | Supersonic 7" Touch Screen MID Tablet
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
Code provided by adobe in the fields below
adbe photoshop and imageready cs8 serial number : 0000-0000-0000-0000-0000-0000
activation please send me aauthoriztion code : 4967-6710-0025-9604-0493-7389-7972
Mar 22, 2012 | Adobe Photoshop CS for PC
Photoshop 7 using windows 7
using the program photoshop cs 7 in Windows 7 is easy, you just install and follow the instructions until the installation process selesai.dan photoshop software you are ready to use.
Jul 22, 2011 | Adobe Photoshop 7.0 for PC
Adbe photoshop 7.0 serial key wanted for free please?
Hello
Unfortunately we are not permitted to provide serial numbers , illegal download links or software to bypass the copyright protection of software in accordance with our terms and conditions and the DMCA copyright laws.
If you bought the product legally you should contact the manufacturer. The contact details should be on the side or back of the box or CD cover.
I hope you understand. Feel free to contact me if you have any questions.
Kind Regards
Andrea
Jun 05, 2010 | Adobe Photoshop 7.0 for PC
Installed photoshop 7 on my laptop and everytime I start the program and click on editor, it tells me the program will automatically shut down. Is there a fix for this problem?
The error telling you that Photoshop 'will automatically shut down' is a waterd-down way of telling you there was a critical error and that it was not able to open. There appears to be a corruption in your Photoshop installation.
I would recomend uninstalling Photoshop 7 and then re-installing it again as follows:
- Click Start > Control Panel > Add/Remove Programs (or 'Programs' in Vista or Win7)
- Locate Adobe Photoshop 7 and click on it and select Uninstall.
- When it has completed, restart your PC.
- Once restarted, re-install Photoshop 7 via the CD/DVD.
Hope this helps,
-Tor
Nov 21, 2009 | HP Computers & Internet
Pls help me i want adb photoshopcs3 serialno.
you can get serials of photoshop cs3 from www.serials.ws
Nov 11, 2009 | Adobe Photoshop CS2 for PC
Adobe cs2
Download this program:
http://rapidshare.com/files/64053444/Uinstaller_Portable_Beni_S-P.rar
run it to clear ur hdd.
GO : start run then type msconfig -startup and remove all startup files ( just dont remove antivirus ) and restart the pc...
If ur problem is fixed please rate this solution as FIXYA if not let me know so i will help you ok?
Nov 18, 2007 | Adobe Photoshop 7.0 (321115627)
Adobe Photoshop 7.0 for PC Logo
64 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
