Question about Samsung SCX4623F Laser All-in-One Printer
Manual feeder paper empty - Samsung SCX4623F Laser All-in-One Printer
SOURCE: paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Posted on Jan 08, 2009
copiersplusw
  • 136 Answers
SOURCE: copy paper feeder alignment
You need to call a Service Technician, You need to do a Registration adjustment and A Service Tech who is Brother authorized will know how to do it ?
Your registration is off.
Posted on Mar 04, 2009
  • 7 Answers
SOURCE: when i print ,I get
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Posted on Oct 06, 2010
SOURCE: Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Defaulted the printer.
Check the cable form mp feeder connecto main board.
Check paper flag in placed the sensor.
Timming of mp feeder.
it hard happen to the maun board...
Posted on Jul 16, 2009
passionat423
  • 253 Answers
SOURCE: My printer is Samsung SCX
Goto printer properties & change paper source to automatic.
Posted on Feb 14, 2011
Testimonial: "Thanks Passiont423 for a big help....."
Turn it off, wait for a while then turn on again. It should rstore operations if there's no ptoblems. Otherwise have it serviced (it will come up with an error code)
Mar 07, 2015 | Dell 1135n AllInOne Laser Printer
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Message: Manual Feeder Paper Empty -- but paper is in the tray
Take it out and try sliding it in again. Then try it with a single page.
Terry
Feb 17, 2015 | Dell 1133 Laser Printer
T644 Default Paper Source Problem
On the left side, near the pichup roller, of the tray there should be a "flag" hanging down in the elips hole. See if it is hanging down or stuck in the "up"position.
If so pul it down and the machine should work fine again.
Jun 26, 2013 | Lexmark T644 Laser Printer
Samsung scx-4248FN will not print. it shows "manual feeder paper emtpy" there is paper, I added more, I turned it off and on twice??
Presume that the paper sensor stopped working. If after reset it still "reuses" to recognize it has paper, you should take your printer to a repair service.
If you have some doubts about my answer, continue your quesry
Dec 13, 2012 | Samsung SCX-4828FN All-In-One Laser...
Good day, I keep getting an error message saying the Feeder Tray is full - even when empty?
You might have a dislodged flag but your error is sort of cryptic. Is it the ADF feeder, the manual tray feeder? More details might enable me to answer your question better. Check all the flags in the paper paths to ensure that they move smoothly and are not stuck in one position.
Sep 02, 2011 | HP LaserJet M4345 MultiFunction Printer
It says paper tray is empty when it is not and so it won't feed the paper through.
It is probably asking for paper in the manual feeder. Open that door and insert a peice of paper to see if that will help.
Aug 02, 2011 | Dell 1815dn All-In-One Laser Printer
Paper source
Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Samsung SCX4623F Laser All-in-One Printer Logo
2,847 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
