Question about Samsung SCX 4521F All-In-One Laser Printer
I get dirty prints , i justrecently changed my toner cartridge
  • 360 Answers
Hello
service your samsung machine i think your laser scanner unit have dust.full service your machine
Posted on Aug 25, 2010
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Ricoh Aficio SP3510SF Toner Change Problem
Step 1:
Good day...
Before we start first make sure the machine is turn-off for our safety process.
Question: 1. Did you try to change the other toner cartridge?
Step 2:
Possible cause and way to check Toner Change Problem & No more Printing:
- Dirty Sensor (check all the sensor)
- Dirty Glass (check all the glass)
- The cartridge is not properly installed
- Full Waste Toner section
- The corona wire is dirty or broken (Inside the cartridge)
- The transfer Unit is dirty or broken (Inside the cartridge)
- Broken gear motor connected into the drum section
- If they have developer include in this model try to check it and
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
- Broken or dirty Cleaning Blade Section
- Check if they have also chips include in the cartridge
Step 3:
Check all the possible cause and try to clean or replace the parts if broken.
Let us know if the problem is solve.
Sorry for my english
thanks
Feb 19, 2013 | Ricoh Office Equipment & Supplies
Pring blank pages
Step 1:
Good day...
Step 2:
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
Step 3:
Feb 19, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
Changed toner---back side now prints dirty with band on the top. Did the cleaning procedure - no luck
If you changed toner because old was empty and now you have this defect with the new cartrige, it is most likley a defective cartridge. Try the old cartridge again, if it prints clean, then you know for sure it is the cartridge. If you purchased a new HP cartridge, get it replaced by HP, they warranty their toners against defects. If you bought a 3rd party toner, return it to where you bought it and get them to replace it. If you had your old toner refilled by someone, get your money back, they don't know what they are doing. This type of defect is often caused by a filled waste toner bin then then runs back out when you print. Some refillers just throw toner in and don't empty the waste toner bin.
Jun 07, 2011 | Office Equipment & Supplies
HP 4P band of grey on left side of the printed page. What should be done? change toner?
hi
very simple
Use the following troubleshooting steps to resolve this issue:
  1. The print cartridge is almost empty. Shake the cartridge gently to redistribute the toner, or replace the print cartridge.
  2. The print cartridge may be damaged. Replace the print cartridge.
  3. The printer's internal mirror may be dirty. Lift the print cartridge access cover, remove the brush from the underside of the cover, and clean off the mirror using the brush.
  4. use p/n 92274A for toner replacement
please issue 4 thumbs up
thanks for using FIXYA
Apr 05, 2011 | HP LaserJet 4p Printer
Paper printing smearry after cartridge change
It's possible you don't have the cartridge properly seated and toner is not being evenly distributed. The other 2 main causes for your problem are:
  1. dirty corona wire
  2. dirty drum
Try cleaning the wire and the drum, then gently shake the toner cartridge from side to side to distribute the toner and re-install. Best of luck.
Greg
Jun 27, 2009 | Brother IntelliFAX 2800 Laser Fax
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
Dirty printing
The cause of this is a faulty toner cartridge. What happened was some toner spilled out of the cartridge and down into your printer. Take the toner cartridge out and with a damp paper towel just goto town and wipe everything down.
Replace the toner cartridge, and in about 20 pages it should clear up.
Aug 18, 2008 | Samsung ML1740 Laser Printer
Workcenter M20i Printing Problem
If the issue is only when you are copying, the scanner needs to be cleaned.
If the defect is on both copies and prints, and fax if you use it for that, then your problem is either the drum or toner cartridge or the laser is dirty.
I am not sure when you say you changed the print cartridge if you mean you just changed the toner cartridge or the drum cartridge.
Jun 17, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
