Question about Seiko Pulsar watch
How to change a battery in a pulsar watch - Seiko Pulsar watch
What is the battery replacement # for a pulsar n944 6a00 ?
BATTERY CHANGE The miniature battery SEIKO SR927W which powers your watch should last approximately 2 years. However, because the battery is inserted at the factory, its actual life once in your possession may be less than the specified period.
Mar 24, 2016 | Pulsar Watches
Pulsar World Chronograph, World Timer
Click on the crown (the stem in the middle on the right side). There are three settings, and one of them will change the minute hands' behavior to normal. You might also check out this guide:
http://c01.coacdn.com/calibers/H800_condensed.pdf
May 07, 2014 | Pulsar Mens World Time Alarm Chronograph...
What type of battery does a Pulsar pxh227 watch take?
The Pulsar pxh227 uses a sr920sw silver oxide battery. An AG3 alkaline battery will also work, is cheaper, but will not last as long as the sr920sw.
Oct 12, 2013 | Pulsar PXH227 Wrist Watch
I have a Pulsar watch with the number VT33-0A00 on the back along with 540966. How do I replace the battery? Thank you!
mcdevito75 here, While a battery change is fairly easy, you will need a set of precision screwdrivers, you can improvise but could ruin your watch, Look for a small watch repair shop in your area the $15.00 will equal your time, effort, and tools you"d need. Plus the battery lasts a year.
Feb 09, 2011 | Pulsar Watches
Pulsar Ladies date watch, approx. 5years old. When battery changed, watch works properly for few days, then it stops. What can the problem be? Does it need cleaning and if so how much?
It is possible the battery was weak to begin with, have the battery replaced to see if that will cure the problem because this a much cheaper way than the alternative.
Dec 31, 2010 | Seiko Pulsar watch
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
Battery problem
Stop panicking, please. If you lost the battery, that means your watch has been opened, so, read the movement number and submit here. Then Ill be able to give exact battery number.
Apr 14, 2010 | Pulsar Expansion PPH520 Wrist Watch
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Dec 26, 2009 | Pulsar Watches
Cannot get the back off a womans pulsar watch
some are twist of which u need a special tool.. dont take it to walmart, they are only a dollar or 2 cheaper then a jewelry store
Oct 06, 2009 | Pulsar PPG672 Ladies
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 | Watches
Seiko Pulsar watch Logo
207 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
