Question about Volkswagen Vw Beetle Kit for 1998 Up
How to change a Starter 1998 VW Beetle - Volkswagen Vw Beetle Kit for 1998 Up
j_del
  • 1586 Answers
SOURCE: 1998 Beetle Lifter noise
They're hydraulic self-adjusting lifters, so there's no mechanical adjustment you can make. Try getting a can of seafoam at the parts store. Pour half the can into the oil, drive 30-40 miles, and change the oil and filter. You may just have some crud in there that is causing one to make noise, and seafoam is good at eliminating that.
Posted on Oct 12, 2008
  • 181 Answers
SOURCE: 1998 beetle - how to get the fuel filter off
The fuel lines are pressurized so you will need to relieve the pressure before you try and remove the filter or you will get a face full of gas. The filter comes off by pushing the fuel line toward the filter and then pushing the quick release button on the fuel line. The fuel line should then decouple - the filter lives under the car near the right rear tire (just in front) Good luck and be careful
Posted on Jun 09, 2009
  • 120 Answers
SOURCE: how to change a 2008 vw beetle headlight bulbs
open hood then remove plastic around required lamp then remove wire & bulb clip remove bulb then insert new one and replace clip put cover on again and your done easy.
Posted on Aug 24, 2009
bschilz
  • 2049 Answers
SOURCE: 1998 vw beetle codes p0411 and p1128
P0411 Secondary Air Injection System Incorrect Flow Detected
The 4mm inside diameter vaccuum hose gets pinched between the lower intake manifold and the secondary air pump housing, flattening it over time.
Here's a link to the steps to fix yourself if you are mechanically inclined...
http://forums.vwvortex.com/zerothread?id=1995162
P1128 Long Term Fuel Trim Is Too Lean
It is very likely this code is coming up because of the vacuum hose as well.
Posted on Oct 20, 2009
jfh1
  • 111 Answers
SOURCE: how to change spark plugs for 2000 vw beetle
With the intake where it is this can be verry hard. You may have to pull the intake manifole to get it done. I can pull 1,3,4 but 2 is a problem. Check with a good auto parts store many times they have people with mechanical skills and loaner tools.
Posted on Mar 17, 2010
Why won't it key start?
Does the car crank (turn over)? If not, you could have a bad starter. If you can kick start the car, that means the security is off (working properly). If security is activated, it usually will shut down starter, ignition or fuel, or a combination of the three. Hook up a voltmeter to the ignition switch terminal at starter, have a helper turn key to crank position and see if you have battery voltage. If so and starter doesn't turn, you need to replace starter.
Oct 24, 2015 | 1998 Volkswagen Beetle
My 1998 VW beetle 2.0 engine sometime when I have stop in the traffic , stop running the engine,had starter egein.
depending where you are, is your car overheating? have u gotten your obd scanned? that should give u an idea of whats going on
Feb 23, 2015 | 1998 Volkswagen Beetle
What transmissions are compatible for a 1998 vw beetle with a 2.0 engine automatic?
vw beetle auto transmission ,,,,to be safe , or just change the fluid which should be about 150 dollars, use only ve fluid , no other
May 04, 2014 | Volkswagen Beetle Cars & Trucks
1998 vw beetle 2.0 standard code p0322 chk engine speed sensor it chks good changed plugs and it stalled again
Resecure loose wire or connectors - If battery charge is low, recharge or replaced battery - Replaced crank position sensor - Replaced starter motor
Dec 16, 2013 | 1998 Volkswagen Beetle
How do I change the headlight on a 1998 vw Beetle?
Lift the hood and if equipped remove plastic engine cover. On each headlight you will see plastic retaining latches. releasing these latches will allow the whole headlight assembly to slide out. Its a canister type assembly. You can then access teh bulbs to replace the lights. it reassembles teh same way
May 15, 2010 | 1998 Volkswagen Beetle
How do I change the headlight on a 1998 VW Beetle?
If it is the driver's side then the air box must be removed. Either side has a lever that you move down and the assembly slips out and you are able to change the bulbs or the assembly.
Mar 28, 2010 | 1998 Volkswagen Beetle
98 VW Beetle Check Engine light
Could be a lot of things, take it to autozone. More than likely they can scan the code for you, they can't tell you exactly what is wrong but they can steer you in the right direction. Give them a call to see if they are able to scan the codes on your VW. Good luck.
Dec 29, 2009 | 1998 Volkswagen Beetle
1998 VW Beetle- Won't start, makes winding noise
sounds like the starter solenoid is bad.
Apr 05, 2009 | 2000 Volkswagen Beetle
Gearbox
This job can get involved, so i would suggest you join up with a VW club online of which there are many to choose from.
Such as: http://www.the-bug-club.com/
At this link you can get all the help you need from real VW nut's
Jan 29, 2009 | 1998 Volkswagen Beetle
1978 VW Super Beetle Fuel Injection trouble
check your mass air flow sensor , it take over fuel pump control after the engine starts
Jun 13, 2008 | 1998 Volkswagen Beetle
Volkswagen Vw Beetle Kit for 1998 Up Logo
118 people viewed this question
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
David Payne
David Payne
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
