Question about JBL CREATURE II Computer Speakers
I accidentally changed my sound settings to something that is supposed to sound like you're in an auditorium. I can't remember what I did but I need to set it back to normal.
    President:
  • 1,851 Answers
The problem is not at the speakers, it's at the soundcard settings. Locate (using your audio mixer panel) the effects tab and set it at no effect (or remove the enabled one).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 25, 2010
How do I fix loss of sound?
Could it be that you chose a setting in your menu that turned it down or off? I would look through all the possible settings and try changing them here and there one at a time to see if I had turned something off accidentally.
Oct 12, 2014 | Fujifilm Finepix S2980
Why is all of my sounds on my labtop echoey?
The auditorium sound effect maybe selected.
Right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' then clicked properties in the lower right of the open window, clicked on the enhancements tab, and change the auditorium enhancements to 'none
May 12, 2012 | Dell Inspiron 7500 Notebook
How set eq 6200
If you have an audio analyzer, you can make the adjustments so reponse is flat across the audio spectrum. Or you can set them so the audio you hear is closest to what you consider a true sound.
You use it to compensate for acoustic defects in the listening space. full auditoriums are going to absorb the high frequencies of the amplified material- so you would set the higher frequencies in a manner that produces the correct sound for something like a piano on stage, the lowest keys get muddied by an audience, as well as the high notes- so they get adjusted higher than mid values. Human hearing peaks between 400 Hz and 1200Hz, so those could be brought slightly below the zero detent- or attenuated.
The short of it is you make the adjustments so the music sounds good and no single instrument overpowers the others unless they are doing a solo.
Mar 27, 2012 | Behringer EUROPOWER EP2500 Amplifier
The problem is that my logitech speakers appears to be playing music as though the speaker is on an auditorium setting rather then playing direct outwards.
The driver software has settings that you can change if on a computer and if on something else there is a setting on the driver someewhere.if nothing else change the driv er
Jun 23, 2011 | Logitech X140 2 Speakers
Something happened with the sound. someone hit a button (unknown which one) on the remote and now there is no sound while watching cable. other devices hooked up to the tv sound just fine.
The sound settings in the sound set-up menu are different and saved for each input (video one, cable, etc.). Go to the sound set-up menu and select stereo and speakers on. Save settings if that choice is offered. You may have accidentally changed settings for one input to SAP or speakers off.
easyab@hotmail.com
Feb 10, 2011 | Hitachi 57F500 57" Rear Projection...
Guys, i am using hp porbook 4420s. the problem is
Sounds like the auditorium is a metal building. Wifi reception is very poor through metal, so you probably cannot use the laptop inside.
Oct 09, 2010 | HEWLETT-PACKARD ProBook 4420s Notebook
My eee pc 105ha audio has a very discernible echo which makes speech almost incomprehensible and gives a ballpark like quality to music.This is unaccepatble. Will the maker take it back?
I had the same problem. Easy to fix:
Start, Control Panel, open Realteck Audio panel and change teh sound effect to none. Mine was set to Auditorium and had a nast echo.
Jan 05, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I need to reset the default settings on my Lexmark Optra S 1625
It sounds like they changed the Paper Type in the menu settings. I cannot remember 100% where it is on this model, but if you go through the menus, you should come across a Paper Menu option. In this menu, you need to change the Paper Type for Tray 1 to Plain Paper.
Feb 25, 2009 | Lexmark Optra S 1625 Laser Printer
ABS light on
thundergod hit the nail on the head with the Jan 28th, 2009 post!
I had a similar problem, took my car back to my mechanic and they fixed it for $45!
They had accidentally (I hope) knocked a wire loose when doing a major repair but warning lights don't come on right away they take a few miles of travel to run through the software in our cars computers before showing up on the dash!
This is why I change mechanics every so often!
Like food, I get sick and tired of tasting the same thing over and over again.
I put 25,000 miles on a year, do a lot of maintenance and repair, and most importantly ...change mechanics every once in a while!
Hope this is helpful.
Good Luck!
96f1613.jpg jackiaria
Jan 19, 2009 | 1993 Jeep Grand Cherokee
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
JBL CREATURE II Computer Speakers Logo
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
