Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer displays E 2 7 that the "printer absorber is full"
    President:
  • 1,138 Answers
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer and start printing again.
1. Turn off the printer
2. Press and Hold both the Power and Reset button for 10 sec
3. While Holding the Power button, release the Reset button
4. Press the Reset button twice then release the Power button
5. Wait until the printer display " 0 " (or RESTART) on the led screen
7. Press Reset button 4x
8. Press Power button 3x and wait for printer to power off
9. Press the Power to turn on the printer
Do this as many times if the first attempt didn't work until it fully reset.
Posted on Aug 25, 2010
Ink absorber full brothers
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Please Visit :- Printer Expert Technician Brother Printer Support
Dec 26, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
The ink absorber is full
So you probably have a Canon Pixma printer with an error code E27 = "Waste ink absorber full or platen waste ink absorber full".
These two tutorial videos will teach you:
1. How to clean the MAIN ink absorbers: http://www.youtube.com/watch?v=VVpjqBr7KjU&feature=fvwrel
But there's a second ink absorber - the PLATEN one - which he does not talk about. The PLATEN is in the black plastic directly underneath the printhead as it slides back and forth. CLEAN THE PLATEN TOO before following the Part 2 video to reset both the MAIN and PLATEN ink absorbers in your software. And don't repeat his mistake when putting the printer back together - the springs he points to at 4:30 WILL fall out!
2. How to reset your printer's internal firmware to remove error alert: http://www.youtube.com/watch?v=4IrBdw7el2E&feature=fvwrel
P.S. Of course it is much easier to bring it to ther printer service (even better if your warranty service can do it for free, if the full ink absorbers error was not caused by too intensive printing, i.e. not your fault).
Mar 06, 2011 | Office Equipment & Supplies
A window displays inktank full and the printing is cancelled, when i give the print command ? what sould i do? when showed to an expert ,he told i need to update the firmware. Is this the solution ,if yes...
I suggest a window display "Waste Ink Absorber Full" or "Ink Tank Absorber Full" . It has to be reset.
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
If that not work just write on kernel84@abv.bg , and i send you a software to reset your printer.
Jan 18, 2011 | Canon PIXMA iP1000
Error 46,the ink absorber pad is full.
first, try to establish if this really is full absorbent pad, remove power cable from the back, wait 20sec, press menu/set key, insert power mains - in most brother printer/faxes this will display machine error code. if this is code 46, you are on the money, your absorbent pad is full (not necessarily, only counter is showing it as such in most cases).
we will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
if that do not work, then maybe really you need to replace absorbent sponge... it is done under warranty and if not technician in service centre.
if you want to do it yourself, remove cartridges, remove fron cover and on the right hand you will have "offending" sponge. either clean it (absorbent, lint free tissue is fine to remove excess first, then few drop of water and repeat draining process with tissue several time, at least till "cake" from the top is removed. best of course will be to replace the sponge with new one.
after that you still need to reset counter. in another way - follow steps...
Jul 29, 2010 | Brother MFC-5460CN All-In-One InkJet...
The waste ink tank is near full
Hi
I found this in a forum you can try it see if it work for you.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Also I found this.
First Clean and Dry the Print Head:
I used a cotton swab dipped in 70% isopropyl alcohol (rubbing alcohol). Do not use too much alcohol.
Then dry the heads, again using dry cotton swab. Be careful not leave any cotton threads on the print heads.
Then I padded dry the spongy Ink Absorbers (one for black ink and the other for color ink) using
Separate cotton swabs for each absorber. Do not displace the absorbers. Or you can replace the ink absorbers at this point if you do not want to pad them dry.
Then Proceed to the Waste Tank Reset procedure below:
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
The waste ink absorber is full
To reset your Canon IP1000 just simply pull out power cord then press-hold power button, while holding power button insert back power cord. You will notice that the power button indicator lights up upon inserting power cord. then you may release power button and start printer. That will solve your "The waste ink absorber is full" message.
Downside is: you may have to do this frequently if your printer looses power. You will understand what i mean.
Jan 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The ink absorber is full What can I do?
if the printer shows ink absorber full on display you have to firsst physically acess the ink absorber pad then clean it up by removing the excesses ink from the pad ,follow the step below to do this
STEP 1:
- Disconnect printer from AC power supply
STEP 2:
Power up with the cover open until the head moves to the left side then disconnect the power cord so that the head is positioned away from the pads. raise The two pads easily with a pair of sharp tweezers and the rinse in running water. it will become white again and can be blotted with paper napkins then air dried in a warm location(may be in an oven) . cleaned the wells in the rubber holdet with cotton swabs before returning the two pads
Dec 19, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon pixma mp160 ink absorber is full
e75ff09.jpg this the reset wast ink please follow it step by step
Jul 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
CANON 160 PRIXMA
E27 = Waste ink absorber full or platen waste ink absorber full
follow the next step
Jul 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
May 16, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
