Intermittent on and off - Computers & Internet
  • 119 Answers
You most likely have a problem with either your power supply or your heat sink/fan. If your computer reboots and states that there has been a thermal error, then the problem is with your fan and cooling system.
Spare parts and replacement power supplies can be purchased through Ebay.
Posted on Aug 25, 2010
Hav n trouble with my intermittent wipers on 1977 ford pu.Work ok first 5 min then they wont go off.Can you help?
No intermittent wipers- wipers will not park after using washer ...
www.ford-trucks.com > ... > 1987 - 1996 F150 & Larger F-Series Trucks
Oct 22, 2006 - I have been having trouble with my intermittent wiper feature and the windshield washer feature and parking of the wipers. For the last two ... Wipers won't turn off......sometimes!
Feb 3, 2014
Intermittent wipers?? (question)
Oct 5, 2011
Intermittent wiper switch
Feb 16, 2010
Intermittent wiper governor bad, need help
Oct 11, 2008
More results from www.ford-trucks.com
Ford Truck Intermittent Wiper Failure
www.misterfixit.com/nowiper.htm
It was a dark and stormy night . . . . actually it was. I had been experiencing someproblems with the intermittent wipers on my '88 F 150 the past week and that ...
Ford Wiper Switch ' eBay
Dec 08, 2015 | Ford Cars & Trucks
My intermittent wiper mode seems to only work on occasion, never consistently.
RAM 1500 Intermittent Wiper Screwed Up / broken. - YouTube
? 0:31
www.youtube.com/watch?v=bljgrhugbBI
Oct 29, 2012 - Uploaded by Jude Augusta
RAM 1500 Intermittent Wiper Screwed Up / broken. ... Update: AFTERMARKET PART (NOT the original) works PERFECTLY: (603) 758-1046 is the CITGO in Hampton, NH ... I lived with it in my 04 Ram but now there is no intermittent - its on or off. ...Replaced the wiper motor - it has the "intelligence" in it.
Oct 23, 2015 | 2004 Dodge Ram 2500
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Sep 11, 2013 | Cars & Trucks
Code 65535 what does that mean
How do i remove t-mobile content lock with out credit card or by going to t-mobile shop.
Apr 05, 2013 | Cars & Trucks
Not cooling, works intermittently.
If you would like free help, the more information you can provide us with, the better and more accurate a solution we can provide you with. How is it not cooling? anywhere, either side, everywhere, one area? works intermittently how? cooling intermittently, running intermittently? Does it make any unusual noises? dose it make any noise?
Nov 09, 2010 | Refrigerators
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
Wipers do not work in intermittent position. They do work in low and high speeds but do not automatically return to the park position. They stop wherever you turn the switch off.
i belive that your wiper switch has gone out on the intermittent side. this is a very common problem.
I hope this helps you
Thanks
Please leave rating
Apr 21, 2009 | 2000 Isuzu Amigo
Intermittanwipers t inop on renault cleo
try replacing the wiper relay
or could be a faulty wiper intermittent part of the switch
Apr 11, 2017 | 2003 Renault 181
98 Saturn SL1 Intermittent Wipers stay on full
Have your intermittent relay checked.
Nov 29, 2008 | 1998 Saturn SL
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
