Question about Microsoft Xbox 360 Console
Can't Establish Player 1
I have four controllers, three of them wireless, and I suddenly can't use any of them. The machine will turn on from the controller and when I use the sync buttons the flashes on machine and controller correspond as if syncing, but once the machine has stopped the controller just continues to blink as if deciding which player to be. What the hell?
  • PlsFixme May 05, 2008
    Yeah, following usual protocol. I also tried holding both, tapping both, morse code, holding together, holding seperately, you name it. But, yeah, normally just pressing sync on machine, holding for a brief moment, then pressing sync on controller. I've had to resync them before and it was never a big deal.
  • Jason May 11, 2010
    Just to double-check, after you press the sync button on the console, you are pressing the sync button on the controller, correct?
  • 21 Answers
I had the same issue when I got my box back from repair. If you have a play and charge kit, I plugged the controllers in one at a time, just to get them resynchronized, works fine now. Give it a try if you have one.
Posted on May 05, 2008
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
I need the code for a ge dvd player my remote is a ge jc021
The codes are, 403,409,430,0409,0430, Step 1. Turn on DVD, STEP 2. Press and hold the CODE SEARCH or SETUP button until the LED light comes on,then release it. 3. Press and release the DVD button, the LED will blink and remain on, 4. enter one of the three or four digit code, the LED will go off, 5. aim the remote at the DVD and press the POWER button,the DVD should turn off, if not try steps 1-5 again using a different code.....hope this helps...
May 20, 2010 | Universal Remote Control GE174Universal...
Only one player recognized-says Maximum no. controllers
Krenwick, did you ever get an answer to this problem. I have 3 controllers and its basically doing the same thing. I've tried everything I can think of.
Feb 28, 2009 | Nintendo Activsion Guitar Hero® World Tour...
Xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
Feb 10, 2009 | Microsoft Xbox 360 Controller
Mi xbox360 controler lite suddenly started to glow by circling
Does it glow in all four quadrants and doesn't go to the player 1 quadrant? If it does, I think I just barely got past that problem! What you need to do is: Turn your controller on (make sure the 360 is on first) press the connect button on the console, then the most important part: HOLD THE CONNECT BUTTON ON THE CONTROLLER! This was a real biggy for me, i just tapped the button instead! hope i helped!
Dec 24, 2008 | Microsoft Xbox 360 Controller
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Wireless controller position
Try this:
Under heading "How can I change the screen positions for my wireless controllers?"
http://www.xbox.com/en-US/support/systemuse/xbox360/resources/supportfaq.htm
To reset the screen configuration for an Xbox 360 Wireless Controller:
  1. Turn off your Xbox 360 console and any connected Xbox 360 wireless controllers.
    (To turn off your wireless controller, power down the system and wait for the lights around the controller's Xbox Guide button to disappear.)
  2. Manually turn on your Xbox 360—don't use your controller's Xbox Guide button.
  3. Press the connect button on the front of your console. This is the small button just to the right of (or below, if your console is on its side) the port for Memory Unit B. The lights around the console's power button will flash as the console searches for a wireless controller.
  4. Press and hold the Xbox Guide button to turn on the wireless controller that you want to assign to slot one.
  5. Once the controller is on and the lights are still circling the power button on the console, press your controller's connect button, located just to the right of the charge port.
    When the lights on your controller stop spinning, the wireless controller is configured to slot one and the upper-left quadrant light will glow.
  6. Select the controller you want in slot two and repeat steps 4 and 5. You can configure up to four wireless controllers.
Sep 01, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
