Question about GE Profile JDP47 Electric Kitchen Range
How to replace control panel - GE Profile JDP47 Electric Kitchen Range
How to replace air controller topside
If you need to replace the control panel altogether, there are a few things you should know beforehand. Before you purchase a new panel, make sure it's compatible with your existing spa control pack. There is often a part number on the existing top side panel when you pull it out of the housing. A sticker is typically on the side indicating a part number from the manufacturer. Otherwise, get the number for your spa control pack and call the manufacturer to find out which top side panel will work for you.
Replacing a topside control panel is a fairly simple process. First, turn off the power to the unit. Remove the spa access panel and take the cover off of the control box and unplug the wire that goes form the topside panel to the circuit board. Gently remove the topside control panel. Remove the plastic from the self-stick backing of the topside controller. Place the topside controller in the place of the previous one. Plug in the topside wire to the circuit board and power back up the spa to test the function of the new unit.
Mar 31, 2017 | Pool & Spa
Where to find WA80V3 control panel
Even if you do replace the panel you still need to get rid of the cockroaches because it will keep on happening. Since the panel may be hard to find I see no other alternative then to replace it with what they suggest. I see no other option except for getting rid of your washing machine and buying a new one, so for the $60 they want to fix it seems well worth it.
Good luck,
Marty
Jul 15, 2014 | Samsung CASE-DETERGENT;WA80V3 -...
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
We have a GE Oven Model JKP70W where the cover on the control panel came off. Can one replace just the cover for the control panel or the entire control panel?
Call GE - 866-622-6184
There is a campaign to replace that part as they are defective.
They will send you the part for free, but charge you $200 to install it. The install is not too hard. Make sure you power off the oven when you do it. Instructions are included.
May 26, 2012 | Microwave Ovens
Panel problem
Hello
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
Restore power to the microwave.
Oct 04, 2011 | Panasonic Microwave Ovens
The "Plus" button for the volume control has
Yes the control panel can be replaced and so can the "plus"button. All you have to do is open it up,take out the control panel and replace the push button for the volume.It might be cheaper than installing a new control panel.
Good luck.
G.
Aug 04, 2011 | Logitech mm50 Portable Speakers Computer...
I need detailed instructions for replacing the front control panel on my Xerox Phaser 8550. The panel is faulty and the company sent a replacement panel but no installation instructions.
on the side rear edge of the panel covering the control panel, use your fingers or a flat blade screw driver and pull the plastic outwards a bit as you gently pull up and toward you, there are no screws, it is held on by 2 plastic tabs.
underneath the control panel sits, unplug it and replace with your new one. then place the front of the panel cover back on and gently push down and rearward , it will click back into place.
Make sure the Control Panel is sitting correctly on its mount.
That's it!
Jan 13, 2011 | Office Equipment & Supplies
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
good luck
Feb 27, 2010 | Whirlpool Ovens
How do I replace the control panel? Where is the
You need to remove the top panel before you can remove and replace the control panel. Remove the screws holding the top panel to the back of the machine and slide the panel backward.
Disconnect the user interface wiring harness from the Central Control Unit (CCU). Pull the dispenser drawer out and press down the release tab at the back of the drawer to completely pull it out.
Remove the screw that was covered by the dispenser drawer in the recessed hole next to the drawer opening.
Open the door and insert a flat-bladed screwdriver into the notch at the bottom center of the control panel to release it.
Press and release the tab behind the right hand side of the control panel securing it to the cabinet.
Gently pry up and release the top of the control panel and pull it off the cabinet.
Install the new control panel in reverse of the steps above.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
Error code EO -F2_
It means that your control panel went out and you need to replace it. Here is how if you want to try your self.
The control panel is not available as a complete part.
To replace the control or touchpad, pull the range away from the wall and disconnect the power to it. Remove the cover on the rear of the control panel. Remove the screws that hold the clock or control to the front wall of the control panel. These screws also hold the touchpad to the front of the control panel. The touchpad connects to the control with a ribbon connector and there is a locking tab holding the ribbon connector to the control. Lift the locking tab and unplug the ribbon.
Dec 18, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Open Questions:
See all GE Profile JDP47 Electric Kitchen Range Questions
GE Profile JDP47 Electric Kitchen Range Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
