Question about Bugaboo Cameleon Jogger
Handle brake - Bugaboo Cameleon Jogger
    Problem Solver:
  • 19 Answers
What about it do you need help with?
Posted on Jun 28, 2008
Can't release parking brake need help
What kind of chrysler? It should release with the brake release handle. Is it a floor mount park brake or a console mounted park brake.Is the brake released with the handle but seems like it is still on/
Apr 12, 2015 | 2001 Chrysler Town & Country
Lost brakes on an 1996 Mxz 800 triple looking for troubleshooting ideas
First make sure you have brake pads left! If you do you may need to bleed the caliper or have the brake assembly onthe handle bar cleaned. Very common problem.
Feb 01, 2015 | Winter Sports
Saturn diagrams
What's wrong? Will the Parking brake engage? Or is it not working at all?
Aug 01, 2014 | 2002 Saturn L-Series
95 Corsica emergency brake not working, pulls all the way back not locking
ray365m hows the rear brake shoes if you have rear drums if there good try adjusting the cables at the bottom of the (e) brake handle pull the boot back theres a 10mm nut to adjust
Jun 28, 2014 | Cars & Trucks
Brake handle does not trigger brake light
Brake switch needs adjusted out or replace. Mike
Dec 07, 2012 | 2005 Honda VT 750 DC Shadow Spirit
Husky 136 and 455 have clutch cover off with brake engaged, handle not pulled in. how can i get the brake to release to put the cover back on?
Most dealers either have the tool or keep an extra handle in their shop just for this.If you can remove brake handle from saw use it to release brake.
Dec 09, 2009 | Garden
How do I repair the handbrake on a 96 Corsica? The brake engages when the handle is pulled up, but there is no ratchet sound nor anything holding it up?
i would remove the rubber boot/cover at the base of the e-brake handle if you can. on most cars there should be "teeth" that engage on another set of teeth. the "button" at the end of the handle should be spring loaded-when you press the button,it releases the teeth engaging each other,allowing the handle to be lifted and pulling the e-brake cable tight.it soubds like your cable is still attached because u said the rear brakes hold.(the e-brake "locks up" the rear brakes). something must have came loose inside the handle or base of mechanism.it might help if u get lucky enough to look near the handle and see if u see any missing parts that might have flew out. if no luck,you might have to get a used mechanism at a junk yard. let me know if this helps.
Sep 03, 2009 | 1996 Chevrolet Corsica
Brake light is on on my 2003 discovery (land rover) brake fluid leaking from the container
Check your brake fluid level. If it is low, that light will come on. If the fuid level is ok, and the switch is ok, check the p/b switch
parking brake switches are usually normally open and go closed when the brake is engaged, the brake handle going up releases the switch and then presses it back down when you put the brake handle down, 9 out of 10 times the switch gets pushed to the side or broken so when you put the brake handle down it does not push the switch down. this would be the first place I would look.
The parking brake light is also an indication of a problem with the brake system
Jun 22, 2009 | 2003 Land Rover Discovery
Trouble with back brakes/cable?
The brake line for the back seems to be stuck, make sure it's tight on the handle bar and the brake in the back is not overly worn or too tight. If the problem presists try replaceing the pads and brake line.
Jun 18, 2009 | Cycling
Bugaboo Cameleon Jogger Logo
160 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
