Question about GPS
Wiring diagram for a 1991 mitsubishi galant vr4
  • 160 Answers
SOURCE: I need a car stereo color coded wiring guide mitsubishi galant ES
They are very easy to find online. Just google wiring diagram for the make and model.
Posted on Aug 09, 2009
  • 11 Answers
SOURCE: 96 Mitsubishi Galant won't turn over
check the charging from alternator if ok you might have a blown fuse ect if no charging 14v id say alternator brushes . or regulator in the alternator
Posted on Aug 26, 2009
  • 811 Answers
SOURCE: need belt diagram for 95 Misibutise galant
buy manual , it could be in the engine compartment
Posted on Sep 13, 2009
  • 1757 Answers
SOURCE: diagram for serpentine belt on a mitsubishi galant es
My sincere apologies for the severely delayed response.
I am going back to answer - unanswered questions. I have only been on this site for the past 4-months. Questions Posted have exploded (+55%) since joining.
I do not know if you still need this information, but I am answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my sincerest apologies...
Thanks.
http://www.2carpros.com/car_repair_information/year/2002/make/mitsubishi/model/galant/2002_mitsubishi_galant_drive_belt_routing_diagram.htm
Posted on Mar 04, 2010
ZJLimited
  • 17970 Answers
SOURCE: i need firing order diagram for 1991 mistubishi
1991 Mitsubishi 3000GT AWD 3.0 liter DOHC V-6
Hope helps (remember rated this).
Posted on Jul 21, 2010
Cv joint on 98 vr4 galant wont come off
Use a prybar to remove the CV joint, place against hosing and gently pry to release CV.
This is assuming you have un bolted the necessary front end parts prior to removing the CV joint.
Jan 21, 2013 | Mitsubishi Cars & Trucks
Need to know how to rewire the evo3 maf to work in the vr4. Car works but is idling high and is not decreasing. I think it may be a prblem with the wiring??
A high idle is caused from a vacuum leak, check the vacuum hoses for cracks, worn against something, any elbows need checked, IAC (idle air control) you will hear a hissing sound, remove the intake tube just before the throttle body and listen for the IAC to close it won't draw as much air if it's working correctly, try cleaning the IAC with throttle body cleaner.
Aug 16, 2011 | 1991 Mitsubishi Galant
I have a97 mitsubishi galant vr4 twin turbo when i drive it some times the revs just go up without me doing anything i touch the gas slightly car revs loud but dont go any quicker
Thats what drive by wire does when the throtle position sensor staqrtsa to go or you have a sensor malfunction do a code search and check the codes first
pep boys or can tire can usualy rent the code scanner for a couple of bucks
May 17, 2011 | 2000 Mitsubishi Galant
I need to check my fuel filter on my 1994 Mitsubishi Galant VR4. Where is it located and whats the easiest way for an unexperienced person?
For 1994 Mitsubishi Galant 2.4L MFI 4cyl the Fuel Filter is located under hood, driver side, upper firewall, mounted in fuel line.
Hope helps.
Apr 14, 2011 | Mitsubishi Galant Cars & Trucks
I need firing order diagram for 1991 mistubishi 3000 gt vr4
Jul 21, 2010 | 1991 Mitsubishi 3000GT
What is most common problem with legnum vr4
i have a 98 vr4 legunm .theres power to every thing but no firer ,would it be the starta motor,
Mar 10, 2010 | 1997 Mitsubishi Galant
Mitsubishi evo/vr4 idle fluctuating between
Galant VR4 or Evo. which car is it?
have you reset the ecu? disconnect the battery for 5 minutes. make sure you have any radio codes if your radio has a security code lock.
Also could be the idle control stepper. Mitsu gives it some name like ICU but it's a small mottor attached to the throttle that opens and closes valves to let a little more air in and up the rpm.if it's sticky try cleaning the throttle and the valves.
May 05, 2009 | 1988 Mitsubishi Galant
I am trying to install a 5in taco gauge and was woundering what do i connect the green wire on the gauge too? its a 1988 galant vr4 model.. any info would be greatful... thanks
its either pin 109 or pin 54. 109 Ignition pulse detect (tach) 54 Power transistor for #1 and #4 coils
the diagrams from the S-AFC has this diagram. which uses pin 54.
i would try pin 109 first, if that doesn't work, try pin 54. its possible that they will both work.
Oct 10, 2008 | Mitsubishi Galant Cars & Trucks
GPS Logo
189 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
