If I have a portable air conditioner and it's not working as cool as before, what is the reason and how can I fix this, please help, thanks!
  • npb17 Aug 25, 2010
    I have set it to the lowest 16 C, but still not cold enough.
  • 4,924 Answers
The issue is the temperature set to be achieve ..I mean the lower point to the thermostat ..set it to a lower value ..and will cool better ..
Posted on Aug 25, 2010
  • Catalin Turcu
    Catalin Turcu Aug 25, 2010
    check with a thermometer and see if it is indeed 16 ..and if there is the value you set ..it means that the room is too big for it ..or it just got old ..and it do not function like it should..but usually this is not a issue that will reflect in the temperature but in power usage ..(consumption).. If the temperature is like you set ..at the exit point it means that it just can not make it out with the space you use it in ...cause it is build for a much smaller enclosure ....If You set it to the minimum value this is all that you can do ..except being sure it is well drained..for the condense ..and that's all..
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Fix My Hinari Air Conditioner
I think the compressor is already busted
Jun 02, 2013 | Heating & Cooling
NewAir AC-14000E not blowing ice cold air
Unfortunately there can be several reasons for your AC-14000E portable air conditioner not cooling well. As with most portable air conditioners the filter grates on the rear of the unit can be removed for cleaning. When those are removed you may be able to clean some portion of condenser coils. There is also the possibility that your portable AC has a refrigerant leak in the system and will not be able to cool effectively without a repair (which usually costs as much as a new portable AC). Portable AC's are not designed to be recharged and operate on a sealed refrigerant line so even finding someone able to repair it may be a challenge. Your best bet is contacting the company you bought it from and talking through some solutions, they most likely have experience with these units and should be able to help you.
Jul 10, 2012 | NewAir Heating & Cooling
THE UNIT BLOWS COOL AIR OUT THE FRONT BUT HOT AIR OUT THE BACK THE MODEL IS aP076E .i DO NOT HAVE A MANUAL BUT IT DOES NOT SEEM TO BE REAL HARD TO RUN THANKS
Yes, that is the way a typical air conditioner works. The portable types need to have the hot discharge air direct outside via flexible hose and an adjustable window bracket. The window closes on the bracket to create a seal, and the hose connects between the air conditioner discharge and the opening in the bracket. This is called "venting". Most portable air conditioners include (or offer as an accessory) a "vent kit" or "window kit".
Some portable air conditioners do not provide a way to vent - fortunately yours appears to have a kit for this purpose. You may wish to check out this page on venting. It has plenty of ideas and suggestions for venting. This site has some very good pictures to document making a vent - and is worth a look, too.
If this was helpful, please rate it "4 thumbs up" - thanks!
Aug 02, 2011 | Amana Heating & Cooling
Hi MY ECLIPASE ac dUCTED AIR CONDITIONER IS GIVING ME A LOT OF PROBLEM. IT IS NOT COOLING THE HOUSE AT ALL, ESPECIUALLY WHEN I NEED IT MOST, ON A DAY LIKE THIS. THE OUTDOOER COOLING UNIT'S FAN CUTS OFF...
Hi is this a portable model or the ones you mount onto a window? The reason I ask is that Portable ac's with a duct tubing that you stick out the window are not efficient. I bought two models from different manufacturers. They can cool down a small room only. And it wasn't even that great. Please write me back and tell me which type it is... =)
Feb 05, 2011 | Heating & Cooling
I HAVE A AN ISSUE WITH PORTABLE AC IT DOESN'T BLOW COOL AIR
dear sir
please make sure first your air con,s compressor is working if it, working and it,s not getting cold then it can be low gas problem or if compressor is not working then please check the thermostat settings and make tempreture correct and setting on cool mode
then i hope if it,s only normal problem then your air con will work again .
after that if not get cold then contact to air con technician for repair it (it,s need to repair and only air con special maintenance person can do it)
thank you
hope answer the question
please vote!
Sep 24, 2010 | Amcor A12000E Nanomax Portable Air...
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Jun 27, 2008 | Amana AP073M 20" Portable Air Conditioner...
PORTABLE AIR CONDITIONER (EVERSTAR BRAND)MODEL MPA08CR NEED HELP TO OPERATE THIS ITEM
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Jun 21, 2008 | DeLonghi PAC85 Portable Air Conditioner
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
