Could not open twain source. make sure there is a valid source for hour scanner in the twain directory found in windows directory
3 Suggested Answers
SOURCE: Genius and Vista
i need driver scanner genius ColorPage-vivid 1200xe for vista
Posted on Oct 06, 2008
  • 332 Answers
SOURCE: I'm getting 2 error messages
I have many years experience repairing Canon scanners so here is my suggestion for you.
This is a common problem with all Canon scanners. If you do a lot of scanning or leave your computer on all the time and never shut it off. What is happening is the memory fills up with all of the images and it needs to be cleaned out. If you reboot (restart) your computer it will clean out the memory and your problem will go away. I always recommend that if your going to be scanning a lot then do it off a fresh reboot and you should be able to your hearts content.
I hope this helps you out.
Posted on Apr 01, 2011
AFTER LOADING SOFTWARE I COMPLETED THE TEST, IT THAT OK BUT WHEN I TRY TO SCAN, PRINT COPY OR ANYHING IT TELLS ME UNABLE TO CONNECT TWAIN SOURCE
Hello.
Give this a try (found online):
Download Irfanview:
http://download.cnet.com/IrfanView/3000-2192_4-10021962.html
Open the main app "i_view32.exe"
With the scanner hooked up, click onto the "file" (tab)
Click "Select TWAIN Source .." and select your scanner in the source box (if it is listed, the driver is functioning)
Click file (tab) then "Acquire"
Hope this helps.
Sep 15, 2011 | Canon CanoScan LiDE 60 Flatbed Scanner
I'm getting 2 error messages when I import the Canoscan D1250U2F from Photoshop: 1) ScanGear CS-U: Cannot communicate with scanner. Cable may be disconnected. Check status. Scanner driver will be...
Mar 04, 2011 | Canon CanoScan D1250U2F Flatbed Scanner
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
I have a Canon scanner 5000f. All of a sudden the computer won't recognize it and says it is "unable to select Twain Source." What do I do?
First you need to follow the instructions for installing the scanner. It is important whether you connect the scanner before the software is installed and whether you work from the new hardware found box or just install the driver as software. It sometimes varies between operating systems as well.
Sometimes the twain files can become corrupted. Since other devices like digital cameras use the twain files they aren’t erased with a driver uninstall or overwritten with an install. If the twain files are gone the driver install will also install them.
Uninstall ScanGear (I think that is the Canon driver software) and remove the scanner if it is still showing in device manager and control panel under scanners. Unplug the USB.
Do a search for twain and delete all you find in the Windows folder. There is probably a folder and several files – delete them all. Do not remove any twain files not in the Windows folder.
Dig out the instructions and reinstall the scanner exactly according to them.
Jan 14, 2009 | Office Equipment & Supplies
Genius and Vista
In a communication with the genius scanner manufacturer, their response is pasted below.
I regret to inform you that the vivid 4 is not compatible with Vista.
Airo
KYE SYSTEMS AMERICA
e-mail support: support@genius-kye.com
MSN Messenger Support: support@genius-kye.com
Phone # 305-468-9250 ext: 30
xp.gif< ----------------------------------------They also state that the product specifically states what it is compatible with and does NOT state it is compatible with Vista. :(
Oct 10, 2008 | Office Equipment & Supplies
Scanner problem
Check to see if you have the directory c:\windows\twain_32 with subfolder for your scanner.
Also check that you have the twain drivers in c:\windows\system32
Sep 16, 2008 | Canon CanoScan D646U Flatbed Scanner
Genius and Vista
There are two common ways to software-connect scanners
to windows:
1) The TWAIN driver interface
2) The WIA (Windows image acquisition) driver interface
WIA is a driver interface native to Windows:
http://en.wikipedia.org/wiki/Windows_Image_Acquisition
TWAIN is a driver interface specific to each scanner
Most new scanners should support both driver interfaces !
TWAIN is preferable, if you can find it, because it is tightly
coupled to the scanner's hardware design, and therefore offers
more functionality, which is hardware specific.
WIA, on the other hand, is more generic.
It will work with many different scanners, but with reduced
functionality, especially in the tools and setting available within
the scanner control window that pops up every time you try to
scan a document from within an application.
If you cannot find TWAIN, you may have to settle for WIA.
(if it will run with your hardware)
This biggest problem, of course, is VISTA itself, and it comes
in two flavors, depending on your computer CPU:
64-bit and 32 bit.
64-Bit Vista drivers are the hardest to find.
32-Bit Vista is a DOG, because the software is too bloated
to run on a 32 bit machine.
Fancy colors and GUI not withstanding, 100% of the added
"new functionality" within Vista is for the benefit of Microsoft
and the scumbags running Hollywood. Vista hi-jacks your
expensive hardware resources and slows down "YOUR"
machine at "YOUR" expense to promote Microsoft's
insestuous relationship with the Sony movie studios and
the RIAA.
I strongly recommend to all my clients to stick with XP for
now, and avoid Vista like the plague.
I do !
Martin
Jul 12, 2008 | Genius ColorPage Vivid Pro II Film Flatbed...
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
393 people viewed this question
k24674
