Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Need to know how to reset codes
I purchased a new image transfer roller and ozone filter and replaced them. But the machine doesn't recognize that I've done this. I'm betting there's a reset code I need, but I've no idea what it is and the five manuals we were provided at purchase are of no assistance
    Problem Solver:
  • 7 Answers
To reset the life counters for the transfer roller & ozone filter you will need to enter the service mode.
To do this press utilty, meter count,details(if available), then stop, 0, 0, stop , 0, 1.
You should now be in tech rep mode, select counters then life.
Select the transfer roller/ozone filter button and press the C key on the keypad.
It should zero the life count.
Now press end, exit etc until you back at the copy screen.
Warning: Please do not reset or clear any other data within tech rep mode or you may inadvertantly affect the performance of you machine.
Hope this Helps.
Posted on May 21, 2008
How to reset ,when i will change developer to the machine model konica minolta Di161
Posted on Feb 15, 2010
  • 1 more comment
  • copierexpres Feb 15, 2010
    how to reset developer of konica minolta D1161
    how to reset developer of konica minolta Di161
    how to reset trhe tech rep mode of konica minolta Di161 machine. when changing developer
Fuser unit
can you explain more the functions of each are as followed fuser melts the toner to the paper so it dosnt rub off ozone filter filters out the ozone so you don't get headaches and turn al the rollers to bubble gum transfer roller pushes the paper onto the transfer belt applying the image to the paper and imagine unit is where thetransfer belt gets the image from
Aug 16, 2014 | Konica Minolta bizhub Office Equipment &...
I have a Konica Minolta bizhub C351 that has an error message " transfer roller unit needs to be replaced soon" I purchased and replaced the "image transfer roller unit 4049-411 that also has the nu
Enter in the service mode:
Press Utility key - Meter count - Details - Counter mode - select present parts life and reset(clear) the transfer roller counter.
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
Where do I find the Paper Dust Remover/Ozone Filter and the Transfer Roller Unit?
I believe the filter is located on the right or left side. The "Transfer Roller Unit" is the foam roller inside the right door.
Apr 07, 2010 | Konica Minolta bizhub C351 All-In-One...
I have a Konica Minolta Bizhub C350 which is now indicating that it needs to have the image transfer roller unite and paper dust/ozone filter replaced. Where are these located in the machine and is it...
I would advise having a copier technician replace those items it is not that hard to do but if you dont get the roller seated in the holder properly it can destroy the transfer belt and that could get expensive
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C450: After replacing the image transfer roller & ozone
In Service Mode -> Counter -> Life -> Select the one you want to reset and press 'C'
May 21, 2009 | Konica Minolta bizhub C450P Laser Printer
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub c351
you have to clear the counters in tech rep mode.
Utility - counter - details- then the following sequence....
stop-0-0-stop-0-1 then press counter - life - then highlight the parts you changed and press the C button, then exit .
Jul 23, 2008 | Konica Minolta bizhub C351 All-In-One...
Need a reset code
hey.
You have to go to service menu ---> stop -> 0 -> 0 -> stop -> 0 -> 1 ---- and choose counter -> maintance/parts counter find these parts on the list, make them blue/touch them and touch C.
then exit to normal mode
good luck
May 05, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Consumable replacement message
You need to go into service mode to reset these parts. Start by hitting the "Utility" button on the control panel. Then select "Meter Count" from the menu. Next hit "Details". Then you need to hit the following buttons in this order, STOP,0,0,STOP,0,1. This will bring you into the service mode on this machine. From there you should select "Counter". From the Counter menu select "Special parts counter". Highlight the parts you replaced and hit the "C" on the control panel to clear the counter. This process should be done for any parts that you replace and will prevent the message from popping up.
May 11, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,576 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
