Question about Belkin (F5D7230-4) Router (587009)
Belkin problem No power to Router-no light came on.was tested nothing happened.
    Problem Solver:
  • 10 Answers
Try other power outlet first. If the router have a power off and on button, then switch it on. Check the router power specs. If you have other device with the same power specs, try it out. If it is still within the warranty of Belkin, try to have the router replaced by them.
Posted on May 05, 2008
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
My belkin router n3000 stopped working out of the blue , internet connection shows up but no internet
Try recycling the router by unplugging it then after 20 seconds plug it back in. See if you can stay connected. If not, unplug the modem and the router, then plug the modem in and let it cycle up for about a minute or two, then plug the router in and let it cycle up.
If you turn your computer and router off at night, then when you turn them back on, if the router boots up before the modem, it will have connection problems. A power outage in the house causes the same thing if the router cycles up before the modem.
Jun 08, 2012 | Belkin Wireless Surf Router (F7D2301)
I have a belkin router it was working fine but then it just looses all power no light nothing i try to push reset but nothing there either what do i do help
No lights on router means no power coming in. Check first if you have any loose ends on the power cord. Try plugging your router to another working power outlet as well. Sometimes, electronic equipments can operate much better if plugged in directly to power outlet than to a surge protector. If all of these doesn't work, then it must be a defective router now.
Sep 11, 2011 | Belkin (F5D7230-4) Router (587009)
My router won't even turn on when plugged in. What's the problem?
need info... is it DOA (Dead On Arrival)? did it happened after a power loss? or all of a sudden? you should first check the AC adapter for power with the use of a multimeeter, try plugging it in a differant outlet, then you could try performing a reset (according to manual instructions) but it could be just dead... these things happen
Sorry!
Jan 04, 2011 | D-Link DIR-628 Wireless Router
Has no power
1. Check to see if there is an on/off switch on the router. If there is then turn the router on.
2. If it doesn't have a switch or you've turned it on and nothing happens then you should check your
wall outlet to make sure you have power. You can test it by plugging in a lamp or other small electrical
device.
3. If the outlet is working, check your surge protector (If you are using one.) the same way you checked
the wall outlet.
4. If the surge protector is working, then check the wiring of the router power supply. Look for any
damage like nicks or breaks in the plastic shielding. If it is damaged it will need to be replaced. These
can be purchased at electronics stores like Radio Shack. They may be available at Belkin.
5. If there is no damage you have a few choices to make:
a. Replace the power cable. This may or may not solve your problem but if it doesn't work with a new
power supply then the router itself is defective/broken.
b. Return the router for repair or replacement. If you have a valid warrenty then this is a good choice
otherwise you will have to pay for the repair/replacement.
c. Purchase a new router. If this is an older router, over 2 or 3 years old, it may be a good time to
upgrade.
Nov 22, 2010 | Belkin (F5D5231-4) Router
Belkin F5D8236-4 Wireless Router will not connect to pannaway dsl modem with same settings as router I am replacing. Dynamic IP address setup. Modem light continously blinks orange. No internet light.
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Oct 03, 2009 | Belkin F5D8236-4 Router
Belkin router just died? What do I do?
There are 2 possible cause of this problem;
First the router's power adapter is already busted if you happen to have a spare or another power adapter with the same output as the original one try it first before deciding to purchase a new one.
Second, the routers processor or the entire board insed the router is already shorted, if it is still under warranty(this model has a lifetime warranty according to the specifications) send it back to the store where you purchased it or to Belkin(some manufacturers and stores also provide replacement for faulty power adapters).
Aug 05, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin 5D3230-4 not working at all
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Feb 05, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
97 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
