I have problem in My Canon printer MF3200, ((Error : Out of Toner change toner)), I changed the toner, and the printer still work but still have red light for Error
  • 4 Answers
SOURCE: Toner light
The HL-2070N gets jammed in a toner end-of-life error condition. Perform the following to clear (I have 120 in the field so I know it works!):
With paper loaded, new toner in,
  1. Open front door
  2. Turn off printer
  3. While holding down the GO button, turn printer back on
  4. When all four LEDs light up release GO button. All LEDs will turn off
  5. Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
  6. Press the GO button 5 times
  7. Paper light will be blinking
  8. At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Posted on Mar 21, 2008
ritzcheese
  • 65 Answers
SOURCE: ML1610 SAMSUNG PRINTER PROBLEM
According to the Manual of ML1610, if the Online/Error light is Red, possible problems are:
• Paper jam occurs.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old
toner cartridge and install a new one.
You may read the manual of the printer for troubleshooting error messages.
http://downloadcenter.samsung.com/content/UM/200709/20070911095810078_English.pdf
Then go to page 69 of the manual.
Posted on Sep 13, 2008
SOURCE: online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Posted on Oct 22, 2008
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
SOURCE: Hi have samsung ml 2240 printer top light is
its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
Posted on Jul 28, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Error set paper again set toner again
after having opened the top and pulled it out. I recommend examining whether there is any evidence of loose toner in the machine at this point.Push the toner cartridge in to make sure it is properly seated.Then close the toner cover.Then close the scanner.
let me know whether this helps the problem any, or changes the machine's status.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon Office Equipment & Supplies
Canon ir 1020
I have canon printer ir 1020, when I need to change a toner the printer detect if the toner that i have putted is empty, but the toner is the new one. what is the problems/ and how to fix it?
Sep 03, 2013 | Office Equipment & Supplies
Canon Ir2018 always indicating ''no toner, change toner''
Because you need to clean and shake the toner unit. When you say " ive been fixing" does it mean that you now what you are doing or?
If yes dismantle the toner unit and vacume it, it may be that toner stucked on "antena" for toner recognitions.
If not - call service
Pls. rate
Apr 27, 2010 | Canon Office Equipment & Supplies
Changed Toner but its still saying "No Toner"
You may need to replace the drum this time. Usually after a few toner changes the drum needs to be changed to.
Apr 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon NP 6050 copier Error
E020 is a toner hopper motor error. This means that not enough toner is being sent to the developer box. It usually is a hard error, meaning that the part has to be changed.
Jun 30, 2008 | Canon NP 6050 Copier
408 people viewed this question
jasbo
jasbo
