I have a Model LAT2300AAE that leaks from the shaft at the tub area. How do I remove the Nut at the shaft bottom to remove the seal?
  • Anonymous Dec 18, 2008
    Leaks on spin cycle
    Genius:
  • 1,073 Answers
You have to have a maytag spanner wrench
Posted on May 05, 2008
Elite model #11027087603. How do I remove tubseal nut on bottom of washer that holds motor rotor on shaft?
that should have an inset, hex-headed screw/bolt. You will have to hold the rotor with one hand and use your other hand to loosen that screw. they use thread lock on that screw, so it will be difficult. but, that's only half the battle. You will have to remove the tub cover, agitator (7/16 agitator nut size), and the spin basket to access the tub seal. the seal has to go on from the inside of the tub assembly. Make sure you don't use anything against the outer lip of where the seal seats inside the tub, or you will have to replace the outer tub because it will still leak. Push the seal all the way down. then before you put everything back together, pour a small amount of water in the tub and see if you see any leaks. anything major will show then, but if there is a small leak, you will not know it till you try to wash with it. You shouldn't have to remove the stator screw or do anything from the bottom side of this unit. You should be able to replace that seal from the top side. good luck.
Nov 28, 2015 | Kenmore Washing Machines
How do i change a tub bottom seal and bearing which is giving trouble to pry out and is leaking water when spinnig
you say u have removed the nut and washer , from bottom usually it takes a spanner wrench to do that, after removing it may be hard and u have to pry it as it can stcik pretty well
Sep 17, 2014 | GE Washing Machines
When the washer goes unto spin cycle, it makes a loud roaring noise and is leaking from the bottom
It sounds like the tub seal is leaking, allowing water to leak out of the tub and damage the drum bearing. Unfortunately you need specialized tools to replace the seal and bearing, so you may have to get a maytag service agent in to look at it. If you're handy with a welder you may be able to make up a tool yourself, it basically consists of a flat hexagon with tabs on the inside to fit the drum nut, and some handles on it. You'll need to remove the front panel and top panel. Then remove the cap around the top of the tub. The agitator is held on by a small screw near the base of the agitator, loosening it will allow you to remove it. Now you can see the tub nut, this is reverse threaded, so it's loosened clockwise. Then you can lift out the drum. Next on the shaft is the top part of the mechanical seal. Remove the grub screw out the side. Now you'll need the same tool you used for the tub nut to undo the seal, rotating in the same direction. Remove the outer tub by undoing the 3 bolts that fix it to the stays, and disconnect the level tube and drain hose. From here you should have printed instructions that come with the new parts to replace the seal and bearing. Please feel free to get back to me if you have any further questions.
Jul 28, 2011 | Maytag Washing Machines
Washer leaking water during wash cycle. Does not
There is a bad seal where the tub mounting with the transmission shaft to cause the leak. It leaks when it tuns. To access this, the agitation fin need to be out so you can see the big nut holding the tube in a place with the shaft. Below this nut is a seal or gasket to prevent the water getting out of the bottom tube. Replace this then you are good . Good luck.
Apr 21, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Vbsr3100dawn washer water leaking between tub hotpoint
Hi, there is a tub seal (WH02X10032) that can be replaced, however, the tub nut generally requires the GE tool to remove. The nut is hex shaped, but is made of a pretty soft alloy so it can break if you use a regular wrench. Once the tub is out, you may also find that you need a new tub nut and split ring.
Apr 20, 2010 | Hotpoint VBSR3100D Top Load Washer
How do we remove the tub seal assembly on a mat12cs commercial Maytag?
This is a not a job for the back yard mechanic. There are many things that need to be done carefully. There are 3 letters missing from your model number also... However the procedure is pretty much the same for all models.
NOTE you will need a special tool to remove the stem seal. Unless you have the special tool in hand don't even bother starting the job. Tell any appliance part center you need the tool for removing an Old style Maytag tub nut and stem seal.
1. Remove the front panel
2. Remove the cabinet top / lid by removing the 2 screws in the top front corner of the cabinet. and rotate the top up 90 deg. Be careful of the lid that will swing freely.
3. Disconnect the pump inlet hose from the bottom of the tub.
4. Disconnect the water injector hose from the tub cover.
5. Remove the tub cover
6. Locate the only hex head screw in the side of the agitator and remove it.
7. Lift out the agitator
8. Using the special tool you should have in hand by now.... Remove the wash tub nut and stainless steel washer under the tub nut.
9. NOTE the distance of the inner tub from the outer tub and then lift out the wash tub
10. Next is the stem seal. You first have to remove the allen head lock screw in one of the 4 faces of the tub nut. Then again using that same special tool remove the upper part of stem seal. Be careful when lifting it as you can actually damage the grease seal in the very top of the tub seal upper portion. Once the metal upper part of the tub stem seal assy is removed... there another NOTE of caution...
11. The actual tub seal has a carbon face on the top of it and if you crack the carbon seal it your machine will leak all of the time there is water in the unit.
grab the tub seal as the very base of the seal and gently rotate and lift it off the inner tub sealing surface.
12. Install the new stem seal.... by again gripping it on the bottom only and gently rotate and push it down into place until it seats level.
Reassemble in reverse order of disassembly but make sure you INSTALL the allen lock screw into the stem seal nut face. If you don't the stem seal will come loose and your unit will leak again. Final note is during re-assembly make sure the wash tub is centered.... rotate the tub once you tighten the tub nut and make sure it is not to elliptical if you don't get it right... the machine will gyrate with use in the spin cycle.
Jan 14, 2010 | Maytag MAT12CS Top Load Washer
My washing machine is leaking from bottom.
It is possible the shaft seal on the bottom of the plastic tub has failed, if you can remove the front cover you should be able to pinpoint the area where it is leaking.
It could also be the large hose running from the bottom of the tub to the water pump, may be split from age.
Also check the inlet hose for leaks
Hope this has helped
Jun 16, 2009 | Washing Machines
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Replace tub seal in top load neptune
I‘ll be watching your progress real close with the Tub Seal replacement. I’m going to run this machine into the ground and I’m sure I will develop a Tub Seal leak down the road. I have nothing to offer other then the mention in the SM on page 49 about making sure “”When installing a new seal, make sure the sleeve from the previous seal has been removed and discarded.””. Did you purchase or borrow this tool to remove the spinner nut Spinner Tool $25, or is there another way to remove the Spinner Nut? Good luck. Rich
Jun 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leak underneath tub
check for a broken seal at center of tub , if so , write down the brand & model and go to an APPLIANCE PARTS SHOP, and get a new RUBBER SEAL KIT, hope this helps , AJ
May 20, 2009 | Washing Machines
Washing Machines Logo
230 people viewed this question
Top Washing Machines Experts
