Question about Home
Who is the top one in helium class - Home
  • 490 Answers
Unsure of the exact nature of your question, but if you are referring to games based on the helium game engine, then helium 3 is pretty popular. If you add some information, we can give you an even better answer:)
Posted on Aug 25, 2010
Hydrogen, helium and methane are gases on earth .why are these substances liquids on the gas giants
The surface temperature.is below the point where their state changes to liquid or boiling point. Boiling Point Degrees above absolute zero: Helium - 4.2 Hydrogen - 20.2 and Methane - 111 degrees (At standard pressure- under pressure the boiling point rises - that is why propane tanks work for energy storage) . Helium Wikipedia
Mar 07, 2018 | Cars & Trucks
I need to 225 cubic feet of helium. How many pounds is that? Thanks!
The difference in the up and down force is 0.069 pounds. Therefore each cubic foot of helium could lift 0.069 pounds. In order to lift 100 pounds (which would include the weight of your load, the balloon, and the helium) you would need 1449 cubic feet of helium
Aug 23, 2017 | Office Equipment & Supplies
What is the definition of isotope
A molecule that has extra or less neutrons this changing its behavior. Eg Trillium is helium with a spare neutron, and is radioactive where helium is not.
Jun 14, 2016 | Computers & Internet
How to reset built in lock on my Delsey Helium suitcase
The default combination of new lock is always 000..If you forgot the correct combination, it is not possible to reset it.
Jan 07, 2016 | Delsey Helium Shadow - 25 Trolley Luggage...
If I buy helium balloons for my daughters party, how long with they last?
Helium balloons are usually made of latex. A combination of that and the helium gas means that the balloons will only last around 8-16 hours so it's best to buy them as close as possible to the start of the party. Some shops have special substances that you can pay extra for that will help the balloons stay up a lot longer.
Jan 10, 2013 | Event Planning & Celebration
Is the Iomega 1TB eGo Helium Portable USB 20 Hard Drive compatible with the sony vaio laptop???
Yes, because it is a Plug-and-Play device, and because Windows supports Plug-and-Play.
Dec 23, 2010 | Iomega 1TB eGo Helium Portable USB 20 Hard...
Clarke 130en Welder settings for Welding aluminum with .030 wire on 1/4" sheet aluminum
try 75 25 argon helium gas or straight helium helium makes metal melt hotter
Dec 11, 2010 | Clarke Power Products Clarke 130EN...
Why do the Omega Seamaster watches have a second crown close to the top of the watch? What is its function?
This is a helium release valve.
The purpose and function of the helium relief valve is a common point of confusion. It has nothing to do with normal underwater diving. Neither does it have anything to do with the depth rating for a diving watch. Helium does NOT seep into the watch while the watch is in water at any depth!
To put it simply, you can completely ignore a helium relief valve. This feature is not used in any way with any form of normal SCUBA diving or anything else that involves less than a multi-million dollar deep sea exploration project.
SCUBA diving activities normally occur at depths of no more than 120 feet. At 250 feet, air becomes toxic due to changes caused by the high pressures at such depths. For those who do very deep sea research, they often use diving bells, dry dive suits, and other types of very deep ocean exploration vessels. In some of these, a highly helium-saturated atmosphere is used to avoid the air toxicity effect.
The purpose of a helium release valve is for people who wear their watch inside the helium-saturated environment for an extended period. Because helium is the smallest atom, it will seep through the watch's seals under the high air (not water) pressures in this environment. If the watch stays in this environment for an extended time, helium will continue to seep in to the watch until the air pressure inside the watch (initially surface air pressure) equalizes to the air pressure in the environment.
This becomes a problem when the vessel is brought back up and depressurized. The helium which seeped into the watch over a couple of days, cannot seep out any faster. The excess pressure inside the watch needs a way to release faster than it seeped in. It is only in this situation that a watch needs a helium relief valve at all. If a relief valve was not on the watch, the excess pressure would likely escape by pushing the crystal out.
But, unless you are in this exact situation, you should never keep this valve open. While the watch is designed to maintain most of its waterproof abilities even when the valve open, it still serves no purpose and increases risk of damage to the watch to do so.
Sep 23, 2009 | Omega Seamaster 2541.80 Wrist Watch
Home Logo
37 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
