Question about Sewing Machines
Husq.2000 Model 6010, Machine does not feed fabric in forward direction, fabric feed in reverse is perfect.The feed dog is not moving across the machine in forward mode.The feed dog button does not appear to be faulty. The fabric travel in reverse varies when stitch length knob is changed
  • 2 more comments
  • kevinj_2 Aug 26, 2010
    Thankyou, we have made sure all knobs and buttons are as per operators manual, we have owned and operated this unit since October 1969. The dog feed button is not the cause of no fabric feed. When machine is operated, the feed dog moves up and down but not across ways, hence no fabric travel. When in reverse the feed dog moves up to the same height as when in forward) and down and also moves across ways moving the fabric as it should do. When watching the 2 shafts that operates the feed dog, only the bottom shaft moves in forward, when in reverse both shafts move, ie bottom shaft creates the feed dog up and down movement the top shaft for across way movement. Re the Model No the machine has 2 numbers on it, 6010 on the bottom plate and 6020 on the side. Cheers Kevin
    Hi , Thank you,
    Knod no1 is for stitch width, the button below No1 disengages the feed dog when pushed in and down it holds the feed dog down below the slotted plate. When this button is disengaged the feed dog is free to move up above the slotted plate.
    Knob 2 is for the stitch lenght, moving the knob to the different settings ie 2,3,4 makes no difference to the across ways travel of the feed dog which should move the fabric forward.
    No2 centre button when out is for forward travel of sewing, when pushed in is for reverse sewing. The reverse sewing works correctly.
    No3 knob is for the stitch type.
    Moving all of the knobs to different positions does not make any difference when trying to sew forward, the fabric just does not move.
    What is the correct adjustment to the forward and reverse button?
    Cheers
    Kevin
  • kevinj_2 Aug 27, 2010
    We have been using this machine since 1969, we have never experienced this problem before. Changing the stitch length does not effect the feed dog operationsin forward sewing mode. The dog feed button when pushed in and down causes the feed dog to stay down below the slotted plate, when the feed dog button is released the feed dog moves up and contacts the fabric but then does not move horizontally to make the fabric move forward. When reverse feed button is pushed in the feed dog moves horizontally and fabric moves correctly.
    Have found machine has 2 model numbers 6010 on bottom plate and 6020 on side.
  • kevinj_2 Sep 02, 2010
    For yoy info, I have tracked down the problem of no forward feed of fabric, the plastic cam inside behind the seam former cam is broken. Hence the machine is out of sync. The knob no 1 can not be rotated when pulled out.
    Thank you
    Kevin
  • 5 Answers
Sounds like you have the buttonhole mode selected, you can verify this by looking at the lower knob it will be more forward than the rest. to fix this just return the knob to 0 and push the knob back in.
Posted on Feb 25, 2014
  • painta76 May 23, 2014
    an additional problem i have just found that this problem maybe caused by a broken cam stack gear
  • Sewing Machines Master
  • 4,924 Answers
Take a look that it has another button in the right down area that controls the feeding dog ..and for some machines is used for embroidery ....this button has to be in the middle to be working right ...it is usually posted under the one that controls the stitch length ...and it has some symbols with a stitch too..but it is in fact the step of the feeding dog ...Im not sure for your model ..but change the position of that button and see which one is the right one for to work ok ..In some position the feeding dog will not get high enough to touch the fabric and this is the reason that the feeding ahead will not work ..
Posted on Aug 25, 2010
  • 2 more comments
  • Catalin Turcu
    Catalin Turcu Aug 26, 2010
    Like I said ..that button I already mentioned cause the feed dog to do not move in horizontal plan when you stitch ahead...(forward )..it has to be placed under the one that normally sets the length of the stitch step ...and the one that operate it forward and rear .....but it is smaller and it is somewhere under..and it only affects the feed dog movement ..if this one is not in it normal position ..than causes this kinda behavior..I will look for the model exactly to let you know what Im talking about ..I m not familiar with the exact word in English ..
  • Catalin Turcu
    OK ..I found a image with some 600 series machine ..and I will try to make myself clear ..
    It is not the same model but I think is similar enough ..at least you will get my point ..
    I numbered the right side buttons ..and I will explain again what I meant..
    as you see I put some numbers on the buttons..and they function like this ..
    1 is the one that determines the stitch step length ..the actual size of the step in a stitch..and the lever is for forward and back ...
    number 2 is probably for the width size when it sews in zigzag (criss cross)..and number 3 should be the one that determine the movement of the feed dog..and if its position is not right this cases what you have ..so even if the buttons are not the same on your machine ..this is what I tried to tell you ..that there is a button that sets the movement of teh feed dog..including the forward and backward ...the values on t are negative and positives...there is the place to look about ..
  • Catalin Turcu
    In this case tale a look around and see if it has any more settings ..cause it has to be one for the feed dog ..usually the one that disengage it ..should have negative and positive values for different tip of movements ..but this one it appears to have not ..anyway it may be a fault of the physical nature than ..
  • Catalin Turcu
    Catalin Turcu Sep 02, 2010
    thank you for the info ...it make sense...it would not synchronize the move..
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
The little Teeth/feeder under the foot doesn't push the fabric out. The fabric doesn't move
check where the direction button/lever is
it controls the feed mechanism and if it is in the middle the teeth will just go up and down
set it one way and it moves forward and set the other way will go in reverse
it is graduated to provide a stitch length ( number of stitches per 1")
Oct 23, 2015 | Sewing Machines
Feed dogs not advancing fabric, only moving up and down
Normally it's good form to give us the make and model number of your machine.
Sounds to me your problem began with operator error. Get in the habit of grasping the threads and holding them as you take your first few stitches. Also make sure your take up lever is in the UP position before you take your first stitch.
Now, look to see if your feed dogs are lowered... if they are put the back up. If this happens again... you've got a warn or broken part.. and you should return the machine. Clearly your "repairman" sold you a lemon.
Mar 14, 2013 | Sewing Machines
Feed dog not moving fabric forward
it would be a good idea to have the feed dogs checked to see why
they are not moving the fabric
Jan 07, 2013 | Brother XL-6562 Mechanical Sewing Machine
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Machine works but doesnt move forward
Could be that the feed dog is in the down position. The feed dog consists of serrated sections which move together under the fabric and move it under the needle. Run the machine unthreaded and you should see the serrated sections lift above the needle plate, move forward and then drop again. If this doesn't happen the "drop feed dog" knob on the front of the machine could be pushed in. Look for a small knob about 1/2 inch across on the right front of the machine. Push on it and move it sideways at the same time. If it pops out this means that the feed dog is now up and you should be able to sew.
Aug 26, 2008 | Husqvarna Viking 1
Sewing Machines Logo
64 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
