Question about HP PhotoSmart 7760 InkJet Printer
My printer is plugged in everything is as it should be. my laptop does not see my hp photo smart 7760 when i go to add printer it shows it but with a caution sign i try to troubleshoot it and the problem is not fixed it keeps saying driver not found my laptop is new it has windows 7 on it its a toshiba
  • HP Master
  • 11,800 Answers
The driver that was supposed to be included in 7 is not there, or it's corrupted.
Unplug the printer from the laptop and reboot. Install and run a good system cleaner (CCleaner will be good enough for you). Reboot and connect the printer - the new Hardware wizard should appear. In there select the option that instructs Windows to search for a driver online - it should be automatically found and installed.
If the wizard window doesn't appear then you must update the driver online yourself by following the official instructions found here
http://support.microsoft.com/kb/323166
Posted on Aug 25, 2010
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Connecting hp photo smart 7350 printer to northgate computer
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Jan 23, 2013 | Northgate Computers & Internet
I want to share an HP 7760 on an XP with Win 7
To get ahead of myself and answer your question first, your Win 7 machine may automatically load a driver for your shared printer.
Please have a look at the procedure below: (these instructions assume that your XP machine is sharing the HP printer and that your Win 7 laptop can "see" your network and the shared printer connected to your XP desktop computer)
On the Win7 machine, follow these steps:
1) In "Control Panel" click "Add local printer"
2) Create New Port > Local port
3) Port Name is "\\xpcomputername\printername" - without the quotes
(insert the XP's real network name and your printer's real name in the above location)
4) Click <OK>
5) Windows 7 should automatically load a driver allowing you to print on the HP connected to the XP from the Win7 laptop.
I hope this helps!
Mar 07, 2010 | HP PhotoSmart 7760 InkJet Printer
HP Photo Smart 1215/1115 condition shows PAUSE. How do I make it return to ACTIVE?
You're reply referred to the Epson Printer On my HP Photo Smart 1215/1115 Printer I went to START then in the window I went to Faxes and Printers then in a new window I found RESUME PRINTING!! It changed Pause to Active.
Jun 04, 2009 | Epson Stylus C66 Inkjet Printer
Need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
Jan 16, 2009 | HP Photosmart Photo Film Scanner (35 mm)
IS THEIR A HISTROY OF BAD POWER CORDS THE HP PHOTO SMART 7700 PRI
If you tried to plug with different socket is mean that the power supply inside printer is broken down there is fuse inside the power supply if you can its easy to change it ..
Jan 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Multiple Computers with HP Photosmart 7760
Purchase a Data Sharer that can connect 2 to 3 PC with your Photo Smart
Apr 24, 2008 | HP PhotoSmart 7760 InkJet Printer
7760 photosmart printer
You may have a leaky green cartridge. Sounds too simple, but try replacing that if you have an extra.
Apr 03, 2008 | HP PhotoSmart 7760 InkJet Printer
Hp Photo Smart Printer 7760
When you open the printer control panel, is there a queue of documents waiting to be printed? If so, delete/cancel all documents, check to make sure it is set to use printer offline (in the file menu), and then try printing a test page.
Dec 11, 2007 | HP DeskJet F380 All-In-One Printer
HP PhotoSmart 7760 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
