SOURCE: My old Russell Hobbs K3
The thermostat is non adjustable and must be replaced. Unless under warranty still, it's cheaper to replace the kettle.
SOURCE: When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
SOURCE: I bought the Russell Hobbs Whisper Kettle
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
SOURCE: I have a Russel Hobbs
You will need to replace the heating element on the kettle. Here is a link to order the part.
