Question about Zanussi WJS1265W Front Load Washer/Dryer
Wont start on any program
On switching on the washer seems ok, you can select whatever programme you want but when you press the start button it beeps once and the LED just flashes and doesnt start the wash. Door locks fine and i had a load in which got a bit of water in then stopped. I managed to get the door open by leaving mains power switched off to get the washing out.
Unit just 6 years old but in good nick! filter on bottom kept clean regular and soap tray cleaned too
Can you help? Ta
  • Pumbaa May 11, 2008
    Thanks for trying Premm,
    I had previously opened up the back taken the valves off to have a look at, moved the machine around a bit... all to no avail, water pressure seemed fine, outlet hose was clear.
    I had called a man out to take a look at it but sods law happened and 5 mins before he turned up it started working again!!! No idea why. He took a quick look and checked the condition of the motor, said the brushes were fine. seems like it might be one of those intermittent problems that will probably come back at some point!
  • Anonymous Jul 26, 2008
    hi where do you find the parts in the machine you describe in solving the problem?
    President:
  • 1,294 Answers
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Water from faucet shd be in good pressure. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
& rate me pl.
Posted on May 10, 2008
When programme is set a key appears in left corner machine wont work
It seems that the program is locked or that there is an error , check the door switch , make sure that the switch is contacting when it is closed.
If this wont solve remove power plug from the mains and press down the start/stop button on the panel after which you must plug in the washer. It must reset to release the lock.
Check the inlet water line , check the vavle.
Sep 15, 2011 | Bosch Washing Machines
Wont let me set program just beeps when pressing program so wont run ( indesit dishwasher
Hi. Are you still having this problem? I just experienced exactly the same thing with my D61 for the second time and eventually I just got cross and held down the P button for a couple of seconds and the machine beeped 3 times and the green light went out. I was then able to select the program as normal. Then, it froze on me again so I held down the button again, it reset again and I tried it on a different cycle. Now it's actually going through the cycle. It's so random (the first time I didn't hold down anything and just shuffled stuff around inside for a bit and then it worked ) it seems to be a actual fault with the programmer, so I can\t say for sure that this will work on yours or even on mine again but it's worth a try!
Mar 04, 2010 | Indesit 24 in. D61 Free-standing...
Maytag Neptune TL electronics problem
neptunes are known for the control board, spin bearing and wax motor going bad. replace unit
Jun 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Jul 24, 2008 | Washing Machines
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
My washer wont choose a programme
push start buttons more than 10 second
Jun 04, 2008 | Zanussi ZWF1430W Front Load Washer
Spin
Electrical module fault
The “Spin Speed” indicator and the “Start
Delay”
option are flashing and an audible tone
sounds. The display shows “F4” to “F16”.
Switch off the appliance. Select a programme
and press the “Start/Pause” button once
again.
The programme will continue.
If the fault re-occurs, contact After Sales
Service (see “After-Sales Service”).
the user man can be found here
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Jan 15, 2008 | Whirlpool AWM8163 Front Load Washer
Selecting cycle and starting
I'm assuming the programs are all selected electronically...then your pc board is on its way out. In this case you would have to replace the board...most electronic boards have "service programs" which you can check functions, but I'm not familiar with Hotpoint.... Oshie
Jun 22, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Fitting new module
just switch off the machine and re start the programming procedure again did you get the programme sheet with the module
Jun 13, 2007 | Hotpoint WMA13 Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
187 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
