Plasma TV 50pf7320a
The plasma TV has audio but no video (no light on the screen)
    President:
  • 2,712 Answers
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
OUR 50 INCH HD AMBLIGHT PLASMA MODEL 50PF9631D HAS SOUND BUT THE PICTURE HAS MANY LINES ANY IDEAS ON WHAT THE PROBLEM IS AND HOW TO FIX??
This is know as the" Blue Haze" defect. A tech may try to lower the screen voltages for you. Realign Ve, 110volts to 100volts. Vset from 195volts to 188volts...and the Vs from 197volts to 190volts. This was an authorized fix early in 2007. But more importantly you will have to live with this, as replacing the plasma screen is very costly. You probably have a bad screen.....SORRY!!!!!!
Oct 20, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Hello, i have a 50 inch philips flat tv model # 50pf7320a/35. why is the screen half black?
Unfortunately, i have found in my experience is when this problem occours you need to replace the plasma panel, which can be a costly thing to do and takes a little bit of planned time. Other than that you can try to replace the X-sus printed circuit board or the Y-sus printed circuit board. Those two boards control the screen circuitry, Good Luck.
Sep 26, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Im just looking to buy a table top stand for my Philips 50PF7320A 50 in. HDTV Plasma can u help?
check online auctions, or local papers, it would b you best bet. Other option would be to buy a entertainment rack that has a big screen mount on it.
Dec 11, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Six blinking red lights when trying to turn on.
The power supply board went dead. Have it repair or replaced. No other way around this. Thanks, mike H.
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
http://www.tivocommunity.com/tivo-vb/showthread.php?t=319984
Oct 16, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Plasma tv
Ok first i have to ask when u turn sound off on TV and get close to the TV does it make a buzzing noise ? If so u have a damaged Plasma panel .
If this is not the problem you could have a bad logic or y-main (most common problem) will need to perform a white screen test on the plasma panel to verify this is the problem.
This is what u need to do
1. Remove the back panel of the TV.
2. Remove the Small Signal Board bracket ( the two long bars on back of the plasma panel, the bracket that is connecting the two with SSB on it, remove this and disconnect the connectors to the power supply (CN1M02,CN1M03, CN1M45)except for the main power plug in you will still need this)
3. Once u remove the SSB bracket you should see a plasma panel resembling pic 1.
4. Place a jumper wire or connect the two pins (CN 2012) on the logic board located underneath the SSB bracket.
5. Also place jumpers on the power supply (J8003 and J8004)
6. Now plug in the power supply, U should hear the relays click and after 5-10 sec you should see a green led on power supply, and 2 green leds on logic board 1 will be solid and 1 will flash.
With this set up you should get a white screen on your TV this will let you know if the panel is bad or not.
Also forgot to ask have u had this TV worked on recently or this just happen for no reason.
May 07, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
