Question about Network Appliance NetApp FAS250 (FAS250RKBASEC)
How can I come back to the initial configuration of a Fas250?
    Problem Solver:
  • 12 Answers
Connect to the FAS250 console by using the provided serial cable.
Logon to the appliance using username 'root' and the root password.
Type the following exactly as shown:
priv set diag
halt -c factory
The filer will reboot and ask for a fresh setup the next time it boots.
This should only be done if you are sure you really want to reset the configuration! This should probably only be done if you know how to then proceed and re-configure the filer.
If you do not have the 'root' password try resetting it. You will have to reboot the filer and type "ctrl-c" when prompted to access the special maintenance boot menu. Then choose the option for resetting the root password.
Posted on Mar 01, 2011
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
I m getting c6 code on my msi motherboard 7642
Hello here is the homepage:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Manual
Make sure ALL the drivers is installed on the mainboard:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Driver&os=All
Post Status
FF Power on and first initialize CPU.
C0, C1, C2 Early CPU Initialize.
C4, C6 Initialize chipset.
D4, D5 Initialize memory.
08 Initialize keyboard.
2A, 31 Initialize onboard devices. Load Option ROM (VGA and RAID
option ROM) form BIOS to memory.
37 Displaying sign-on message, CPU information, setup key
message and any OEM specific information.
38 Initialize USB device and different devices.
3C Mid POST initialization of chipset registers. Detect different
devices (parallel ports, serial ports and coprocessor in CPU...etc.)
75, 78 Initialize INT 13 devices and IPL devices. (include SATA/ PATA
HDD and CD/DVD ROM).
87 Enter setup screen. BIOS setup if needed/ requested.
A4 W ait for user input at configuration display if needed.
A7 Display the system configuration screen if enabled.
B1 Save system context for ACPI (Advanced Configuration and Power
Interface). Prepare give control to OS loader (INT 19H).
00 Pass control to OS Loader (typically INT 19H).
AA Enter OS (Vista or W indows XP).
Look also here:
http://www.dewassoc.com/support/bios/awardbios_error_messages.htm
Did you upgrade the ram memory, or the cpu ??
When and how did this problem occur ??
Jan 31, 2013 | Computers & Internet
Se-c300 e004
The initial setup has not been completed. Take it back to your dealer to have the initial settings configured. This should have been done before it was sold to you.-----------------------------------
If anyone needs a manual for the casio SE-C300, try here:http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-C300_users_and_programming_manual.html
Dec 15, 2011 | Casio Parts Cash Register PC Desktop
How to mute alarm Netapp fas270
There is a black button on the back of the FAS270 that will allow the hardware-beeping alarm to be muted.
Sep 12, 2010 | Network Appliance NetApp FAS250...
My wl-600g router initialize but can't get to net
go back and check your settings for the router--make sure everything is configured for the network. all the lights will be on even if something is connected wrong or not configured. correctly.
Apr 30, 2010 | ASUS WL-600g Wireless Router
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
I am looking for the part number of the CMOS battery on a FAS250
A Vendor that I had a releationship with was able to source that part number.
Jan 05, 2010 | Network Appliance NetApp FAS250...
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
initializing the hard disk before replacing it.
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
Computers & Internet Logo
697 people viewed this question
Top Network Appliance Computers & Internet Experts
David Payne
David Payne
Are you a Network Appliance Computer and Internet Expert? Answer questions, earn points and help others
